Question about Avanti 18CYW Compact Refrigerator
Avanti issues my compact avanti refrigerator is not cooling, the fan is not turning and I have only had it maybe a year
  • 87 Answers
Take this unit back even if you bought it used and get a new one it is still under warranty.
Posted on Oct 07, 2008
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Refrigerator is not cooling properly. Warm all the time.
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Jan 28, 2011 | Avanti EC15W-2 Compact Refrigerator
My Avanti refrigerator (about 12 cubic feet) is freezing everything in the refrigerator section.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Avanti 248Y Compact Refrigerator
Refrigerator model 309YBT quit working on Friday
Good day,
You did not say if it was running or not.
If not running at all, then it may be the cold control, (thermostat) that has failed. You can remove it, jump the 2 wires going to it, and see if it runs and cools.
If so, you may be able to contact your local appliance parts house for a replacement.
However, if running and not cooling, then 2 options.
1. If under 5 years, sealed system should be under warrant. Call your selling dealer for details.'
2. If over 5 years, not price effective.
Nov 16, 2009 | Avanti 309YBT Compact Top Freezer...
I have an Avanti outdoor refrigerator. It's about
Try to place on flat ground surface, u can balance its weight. Check compressor fan if its making noise.
Nov 05, 2009 | Avanti BCA5102 Stainless Steel Compact...
Avanti refrigerator not cooling
thermostat set ? might not be defrosting all the way. damper actuator not opening from freezer to refrigerator. is the condenser clean?
Jun 17, 2009 | Avanti EC15W-2 Compact Refrigerator
Not getting very cold
thermoelectric needs a good heat dissipation. Give the unit a good ventilation to dissipate the heat, you will cool the unit. The cooler the ambient, the cooler the box. Remember not to reverse the switch, you will get a heated box instead.
May 24, 2009 | Avanti Compact Thermoelectric Refrigerator
Under counter beverage cooler
It might be ice around the fan. Try defrosting it. This has been happening to mine, even through it is supposed to be 'frost free'
Jan 15, 2008 | Avanti 310SST Compact Refrigerator
Fridge temp high
freon and a compressor is about as easy as it gets....Loss of freon will cause erratic cooling...also if you can feel it touch the compressor after it shuts off if if feels like its really hot ....bad compressor that kicks an internal breaker....bad news then time for new one also only a airconditioner man can put freon in no 12 . but freon will stay for 50 to 80 years for i tested some old fridges and still cool fine.
Aug 31, 2007 | Avanti 310SST Compact Refrigerator
Avanti compact Refrigerator NOT COOLING
I had this same problem. I did some troubleshooting and figured out that the fan was being bogged down by ice. It wouldn't spin because the ice was so heavy. I turned the power off completely and let the ice melt. Once the ice was removed from the fan, the fridge began working again!
Feb 16, 2007 | Avanti EC15W-2 Compact Refrigerator
Avanti 18CYW Compact Refrigerator Logo
337 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
