Question about Admiral Refrigerators
My fridge freezer has stop working but if you open the door it start to work but if you shut door it stop's and you can hear the fan in freezer stop and start it's a admiral gc2224gekb side by side
  • 943 Answers
Hi thanks for te question. it should be the opposite of what its doing did somebody work on this fridge before. it looks like somebody switched the light and the fan switch
Posted on Oct 07, 2008
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
My Liebherr CNes 3366 fridge freezer has started to build up ice in the bottom of the freezer. How do I check the fan in the fridge is working, (I never see it going)as it may be the cause? thanks r
remove cover and test with a meter or push door switch when door open and should hear fan hum or feel air when door open fan stops unless you push switch
Apr 20, 2017 | Liebherr Refrigerators
How to fix a hotpoint frost free fridge freezer
I would call a repairman . possibly the fan has worked loose on the motor shaft
Oct 08, 2015 | Total Micro HDP80CF72-PAN 80Gb Notebook...
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Apr 19, 2015 | Refrigerators
Freezer working fine, fridge not at all
Brand name and model would help but here is a guess. Most frost free refrigerators have the main cooling unit in the freezer area side. To get the fresh food side cold, there is a small fan in the freezer side that blows cold air to the fresh food side through a duct work or trap door. If that fan stops or fails for and reason, the first place you will notice the temp rise is in the fresh food section. See if you can hear the freezer fan running. You may need to push in the door switch for the freezer light to hear the fan because they sometimes run the fan wiring through the door switch. It may stop when door is opened.
Apr 03, 2015 | Refrigerators
I have a kitchenaid superba ksrs25ilwh side by side fridge. The freezer is working fine but the fridge wont get cold enough even at the lowest temp
check the damper vent door for proper opening and closing as if this door is frozen shut or broken and jammed it cant open to let cold air in from freezer it will be behind a plastic grille between the freezer and fridge compartments and you should hear a fan in there running to move cold air too
Jul 02, 2011 | Refrigerators
My refrigerator side is not cooling well. I see ice behind the fan unit when I take out the veggie drawers at bottom. Also fan on fridge side is making lots of noise. Noise stops when I open the door and...
.When you open the door freezer door will get stopped and so, no sound. It will work only when door is closed. Fan sound comes due to malfunction of defrost. If defrost does in right time it won't happens. Unplug and let fridge get defrost all icing. After 3 to 4 hrs,start run again, and set temp @ 5degree freezer. It will start cooling fridge compartment also. But, this is a temerory solution. To solve permanently, find out why defrost not functioned properly?
Follow this steps.
Check defrost timer working which is back of the refrigerator down corner. By with small tip screw driver in some models located in the ceiling of the fresh foodsection or behind the cold control cover. In the defrost timer,slowly turn the screw like wheel in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Jan 28, 2011 | Samsung RS2630SH Side by Side Refrigerator
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
The fridge and freezer is not chilled
power to the house was shut off for repairs, when power was restored the freezer part of the fridge stopped working but the compressor still runs.
Mar 19, 2009 | Hotpoint HSS25GFP Side by Side...
Kenmore 5355
There is a fan inside the freezer which circulates cold air through the air diffuser and then through the return duct at the bottom of the fridge. This fan may not be working. You should be able to hear it when you open the freezer door. If you cannot hear the fan going with the door open, keep the door open and press the button that switches the internal light off. The fan should run. If no fan running in freezer test for supply to fan. The fan may be faulty or the thermostat which is in line with the fan could be faulty.
Oct 29, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
226 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
