Question about Hunter Dryers
Ceiling fan makes a clicking noise
Our ceiling fan which we never turn off except to clean just started to make a clicking noise which drives my husband crazy when we try to sleep.
Is there any way to oil or fix this problem? The fan is only a year old and wasn't cheap.
Thanks
  • Anonymous Feb 25, 2009
    I have a Hunter ceiling fan that is 10 years old and has started having a clicking sound. It does it off and on and is very frustrating. Looking for a solution.
Just apply some lubrication and if necessary change the ball bearings. u r all set
Posted on Oct 07, 2008
My bathroom Broan exhast w/light makes a constant clicking / tick tock sort of noise when the fan is not running. as soon as I turn the fan on the noise stops and then stops after I turn the fan off, only...
remove the cover and clean anything in the vent , check the fan for anything that could be touching it, as the back draft comes through the vent, something could just be touching the fan blade as this draft makes the blade turn slowly, which would create a ticking noise
Jul 10, 2011 | Broan-NuTone (8663RP) Ceiling Fan
Someone helped me install a ceiling fan. I told them that I here a clicking noise still , they said to go back and tighten every screw. I did that but the clicking noise is still their. What are my...
Check that all the blades are aligned when the fan spins. If one blade is higher or lower than the others it throws the fan out of balance and makes a clicking noise. Also check that the pitch on all the blades is the same, this has the same effect. The blades can usually be bent just a bit to correct any misalignment.
Jun 09, 2011 | Hunter (25417) Ceiling Fan
Light flashes, clicking noise, fan does not turn
it sounds like the motor has a weak start winding or if the unit has a start capasitor it is bad
Feb 05, 2010 | Reiker Room Conditioner Ceiling Fan with...
Have a broan n688 ceiling exhaust fan in bathroom and now it takes a couple of minutes to actually start, finally making a whirring noise before coming on. Solution?
First turn the power to the fan OFF. Take it down from the ceiling by removing the screws holding the cover on. Then remove the screws holding it to the ceiling. Then unscrew the screw caps that twist (connect) the wires from fan motor to the house wiring. Do a general clean up on the fan. Use an old paint brush to get in the hard to get at places. Rotate the fan by hand. If it does not rotate freely, put some oil on the shaft where it goes into the motor, and put some on where the shaft comes out the back. If it still does not rotate freely, buy a replacement and install it.
Oct 07, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
52 inch hunter ceiling fan with remote, making clicking noise
does the fan wobble at high speed? if so change the order of the blades to try & balance it.i.e. number the blades on a piece of tape on each--switch blade # 1 & #3-better or worse? 2&5;better or worse?etc. untill it runs smoothest.
Sep 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Lightning causes ceiling fan to make clicking noise
sounds like surge shorting
call in an electrician to check the installation of the unit
Aug 06, 2017 | Hunter 20761 52'' The Stratford II Brushed...
Fan makes noise
try to find the manual through the internet. Look for model number and name of product then click manul to your chosen then it should be no problem to help you find it better!
Jul 18, 2008 | Hampton Bay Cessna 04313 Ceiling Fan
Dryers Logo
3,988 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
