Question about Copystar Office Equipment & Supplies
Copystar cs1815 error code c6050 - Copystar Office Equipment & Supplies
    Genius:
  • 2,120 Answers
You probably need a new fuser.
Posted on Oct 07, 2008
Copystar s 2085 error code c5
A complete list of Copystar error codes is here:
Copystar Error Codes
Nov 03, 2013 | Copystar Office Equipment & Supplies
What do I do to remove error code c6050
Did you changed fuser unit?
1. poor thermistor connector contact
2. thermistor broken or installed incorrectly
3. thermal cutout triggered
4. heater lamps broken or installed incorrectly
check thermistor and thermostat continuity and replace if necessary; check heater lamps installation and continuity and replace if needed; perform sim163 to reset the error
Aug 15, 2012 | Kyocera Copystar CS-5035 Copier
Error code c6000 of copystar cs1815
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 20, 2011 | Kyocera COPYSTAR CS-2050 Printer
Driver needed for kyocera cs1815
Try this location:
http://www.driverstart.com/start318276.html
Jul 11, 2010 | Kyocera Copystar CS-1820 Black and White...
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Code C6050
You have a FUSER problem. You need a technician to repair
Feb 08, 2010 | Copystar CS-4035 Copier
Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
May 25, 2009 | Kyocera Mita KM-2050 Printer
Error: Call Service Code: C6050
try to press code 10871087 then 163 and lastly press clear/stop button for a while.
Nov 17, 2008 | Copystar CS-1620 Copier
Copystar cs1815 c6000 code
This is a fuser problem -- here is a reset method:
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
Aug 18, 2008 | Copystar CS-1815 Printer
148 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
