Question about Mitsubishi WD-62525 62" Rear Projection HDTV
WD-62525 part #915P026010
Where can i find this part (light engine?) #915P026010 ???? and how much does it cost?
  • 10,594 Answers
Part number ( #915P026010 ) you wrote is called Lamp (bulb) of Mitsubishi DLP TV.
This part is available on Parts Store approx on $200
Thank you.
Posted on Oct 07, 2008
SOURCE:
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
Does the wd62628 have a factory reset button?
should be in the manual. Or you can look on line for Mitsubishi model wd62627 owners manual download.
Sep 09, 2014 | Mitsubishi 915p026010 Wd-62627/Wd-62628...
Check engine light came on, why?
the check engine light is on to tell you that something serious has happened to the engine /gear box units. Check oil and coolant levels and the engine for overheating. Run fault codes as soon as you can as the cost now may be low but to ignore the light will result in a costly exercise.
Mar 02, 2014 | 2001 Pontiac Sunfire
What is error code 42 on wd62627
Double check as no 42 is indicated on their site.
Nov 29, 2012 | Mitsubishi WD-52627, WD-52628, WD-62627,...
I recently replaced a 915P026010 bulb for a MiTSUBISHI WD-62628 tv and it gives me a blinking yellow light in the lamp led indicating that the lamp housing is not installed properly. I have re-installled...
Make sure lamp cover is also fixed on tv cabinet after lamp installation.
If lamp cover has not been put on its place, tv wont turn On due to safety switch inside that place that gets press with lamp cover.
Thanks.
Jun 24, 2011 | Televison & Video
We have sound but no picture, help!
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 4000 hrs,1-3 yrs it could be time to replace the lamp.The lamp you need is 915P026010.Here's the instructions to replace it: http://www.fixyourdlp.com/guides/mitsubishi/915P026A10.php Have a blessed one!
Mar 29, 2010 | Mitsubishi WD-52628 52" Projection HDTV
KEEP GETTING CODE 37
From your description Code 37 means either DMD board deffective or lamp fan stopped.so in your case fan is good I would suggest replace light engine.because DMD board is the part of light engine.
Part number # 915P026010
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
196 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
