Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Freezer drawer sticks
Freezer drawer on Kenmore Bottom Freezer model is sticking. Won't open smoothly especially on one side. Does it need grease. How do you remove the slides? Do I need to?
  • myhotmail69 Oct 20, 2008
    I have the same probleb and the fridge is just 1 year old. The rails are mad of steel instead of stainless steel. This is a Kenmore factory design problem and also to cut down on their cost. I paid a lot of money for their applianceas and am now sorry I dealt with Kenmore.
    Bob
5 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Maytag Frenchdoor w/freezer drawer - drawer sticks
you will need to remove the front and get to the slides clean them off and buy a low temp silcone to apply to tem do not buy grease apply it and work it in the problem will go away
Posted on Jan 24, 2008
SOURCE: Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Posted on Jun 16, 2008
  • 62 Answers
SOURCE: Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
Posted on Aug 30, 2008
  • 163 Answers
SOURCE: GDS20SBSBSS FREEZER DRAWER WON'T OPEN
ice will most likely form again.you have a defrost problem.most likely it is your defrost heater.their are a few things that control your defrost cycle.defrost timer,thermostat and defrost heater.most of your newer ref. will also have a control board on the back of ref. or under ref in a usually grey box.but check your heaters first.you will need to take the back panel off in freezer.you will see heater at the bottom of coils.if you have a set of meters you can check for continuity to heater.also your drain below heater sounds clogged.i usually steam out drain but you can use hot water.water should go down drainwhen unclogged.that will prevent the drawer from sticking.
Posted on Mar 07, 2009
  • 3 Answers
SOURCE: Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Posted on Apr 02, 2009
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
Freezer drawer closes on right but gaps on left side for Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator, frosting contents. No contents blocking. Can manually hold left side closed, but wont...
I had this problem with my Kenmore bottom freezer drawer also. I found that the problem was I had too much weight at the very front of the drawer. Try reorganizing and moving items, especially heavier items away from the very front. Worked for me.
Jul 10, 2009 | Kenmore 73503 Stainless Steel Bottom...
Feeler arm on ice maker prevents freezer drawer from opening
Hi, There is no adjustment on the level arm other then bending it. Is it posible that something snagged it as the drawer was being pulled out and bent it? The arm should collapse all the way down tothe side of the icemaker and level with the bottom of the icemaker.
Hope this helps. Please let me know if I can help further.
Vic
May 11, 2009 | Refrigerators
Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer Drawer won't open on Kenmore 22" Bottom Freezer Refrigerator
Try raising the door. It may be off the roller tracks inside. If you get it to open you'll find the problem. These tracks are like kitchen drawer tracks.
Jun 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore coldspot
Behind you crisper drawers is an opening to the freezer compartment for air return from the refrigerator. If it is blocked it can cause the problem you posted. The temperature of the refrigerator section controls the running of the system.
Jun 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Jan 23, 2008 | Maytag MFD2560HES Bottom Freezer French...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
161 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
