Question about Hotpoint Dryers
I have a ctd00p dryer and cannot get the worktop off to change the heater! I have removed the two screws at the back but can't pull the lid back! I've also tried raising it and pushing it forward but to no avail! I'm sure there's some easy explanation, please help!!
  • eddie0001 Oct 09, 2008
    Thanks Tresilla, but there's definitely only the two screws holding the worktop on!
    It needs to come off to remove the side panel to get to the contacts for the heater. I didn't see an obvious way to get the back panel off. It can only be the heater or stat though, can't it? Any further advice would be appreciated!!
    President:
  • 1,462 Answers
I remember there are three screws - one in the middle as well. may be wrong. having undone all screws, just bank front of top with hane and it will slide back.
however, no need to remove top to replace heater - take back panel off and heater is exposed. and how do you know it needs replacing if you haven't tested it??
Posted on Oct 08, 2008
What does code E 64 mean on frigidare affinity dryer
If your Frigidaire Affinity dryer is beeping at you and giving you the "E64 CALL SERVICE" business, chances are you have a bad heating element. The good news is, with a screwdriver, a pair of pliers (a multimeter if you have one) and a new heater element you can fix this yourself and save a couple hundred bucks.
First you'll want to unplug the dryer and shut off the water source.
Then disconnect the vent hose and the water feed (if applicable). Be sure and shut off the water valve first, or you'll have a mess!
Next you need to remove the lid, the back and the lid brace. To remove the lid: remove the screws and pull straight back. It may resist a bit at first. If it does, wiggle it a bit and it should break loose
Now remove all the screws holding the back piece on. Don't forget the ones in the middle, including the access panel.
The brace screws are are next. After you get the brace unscrewed, just pull it up and out of the way
Next (if you have a pedestal), remove the top screws of the pedestal brackets. Note: these screws are slightly different, so keep them separate.
Now you'll want to remove the screw holding the vent tube in. It should be screwed in at a slight angle. After you unscrew it, push the tube in as far as you can to facilitate removal of the back.
Now unscrew the power connection (you did unplug the dryer first, right?) and remove the back. It may take some effort to clear the tube, brackets and water connection. I usually pull the top out at a good angle and work it back and forth to free it.
Now that you have the back off, you can pull the vent tube out and move it out of the way. The heating unit is on the right and you'll need to remove 3 screws and some wiring connections to free it.
Now that the unit is free, turn it so you can pull it out, It may take some doing, but it should come out without too much trouble.
Once free, if you have a multimeter, you can test the coils. Set the meter to the lowest ohms setting and test each coil. You can also do a visual inspection, although it might not be obvious.
Once you have verified the problem, via multimeter or visually, you can replace the part and reassemble. WARNING: When reassembling, do not over torque the screws. Sheet metal bends very easily. Snug is good!
Reassembly is basically just the reverse of removal, however you may have trouble with the pedestal brackets when putting the back cover on. If you do, loosen the bottom screws on the bracket to give a little more wiggle room.
The new part will likely not have the mounting bracket attached, so be sure and not damage it when removing the heating unit.
https://electronicshelponline.blogspot.com/
Nov 09, 2016 | Dryers
How do I remove the lid off of a GE dryer
Try: http://www.appliancerepair.net/clothes-dryer-repair-4.html
They can probably help, especially if you have a reason to take the top off and it is not performing properly.
Apr 01, 2015 | GE Dryers
No power to myctd80 dryer
if i remember rite ctd40 has three stats over heater 1 has pin hole in top push needle in hole to reset it and take needle out then try ive done this on sum
Apr 01, 2013 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
I can't see how to remove the worktop of my Bosch dishwasher. I found two screws that look as if they stop it sliding forward but I still can't move it after removing them. It looks for all the...
Hi john_mchugo,
The dishwasher Worktop can be removed by first removing the 2 screws at the back of the machine. The screws are either fastened horizontally, or vertically. Once these screws are removed, the worktop slides backwards, and can be lifted up and off.
On some models there are catch tappets located on the rear right and left hand sides of the Top panel. To remove the Top panel, press up the catch tappets, push the worktop back and lift it off. If these tappets aren't pressed up, the Top won't release at all.
I hope this has helped you.
Kind Regards
* If this solution helped you, please accept it
Aug 18, 2011 | Dishwashers
Hello I need to get to the belt on my dryer how do i get to it?
Unplug the dryer.
Remove the 2 screws under the lint filter lid.
Remove the lint filter.
Use a putty knife to push in on the 2 clips on the right and left front between the lid and the front panel.
Raise the top lid and move it to the back of the dryer.
Look inside the right and front corners and remove the 2 screws holding the cabinet case to the front panel.
Remove the wires from the door switch.
Pull up and out on the front panel.
You are now in the dryer.
May 24, 2010 | Maytag MED5700TQ Electric Dryer
WHIRLPOOL ELETRIC CLOTHES DRYER MODEL# LER4634EQ0 Dryer drum turns but is not heating
go to the back of dryer where the plug connects to the dryer and make sure you have 240 volts,if you don't check the house fuses,unplug the dryer remove the vent line and take off the back panel,on the left side you'll see the duct that the lint filter slides into,to the right of it you'll see a white thermal fuse part 3392519,pull one of the wires off and check it with a meter,if that's bad you need to clean out the dryer,pull out the lint filter and remove the two phillips screws on top,now take out the four screws holding the duct in and clean it out,pull it out and push it to the right so you can clean it.clean out the vent line and the vent outside,if it's a long run from the dryer to the outside vent i use a leaf blower to blow out the line,you should do this once a year,you should pop the top of dryer with a screw driver lift up the top lid,take out the two 5/16 screws one on each side and remove the door switch wires and pull up on the front panel to remove it and clean out the inside of dryer also.if the fuse is good,read out the heater and the thermostats on the heater box,ifyou're not getting 240 to the heater you could have a bad timer,go here and put your model number in and you can see your dryer and all the parts,hope this helps you,if you need anything else let me know Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com
Mar 09, 2010 | Whirlpool Dryers
How do I remove the heating element?
Take the lid off
4 screws usually to the back
pull lid back and off
remove the kick panel
Make sure you have turned the power off or unplugged unit
you are going to have to take the front off where the timer is to the very left and right look down about 4-6 inches you will see a screw on each side remove them
unplug the quick disconnect from the timer attached at the top right
you are going to have to cut the zip tie as well
take the screws out of the bottom of the door there are 2
peal the front off
you will have access to the drum now
behind the drum is your heater
you are going to have to take the belt off of where the motor is
you are going to have to lift the drum up and out...it is sitting in a little holster and it might be a struggle.
after you remove the drum
you will see the heater
in the very back of the cabinet are the screws that hold the heater in place
ARE YOU SURE IT"S YOUR HEATER
DID YOU CHECK VOLTAGE AT THE WALL FIRST FOR 240 volts
DID YOU MAKE SURE THAT YOUR EXSAUST IN THE WALL IS CLEAR?
let me know if you need more help
Feb 07, 2010 | Frigidaire Dryers
Model no GLER642AS3, how do I change the heating element
there are two clips about one inch in from the sides of the dryer.push these tabs in to unlock to lid.there is a small access panel on the bottom left side of the dryer.this willa llow you to take the belt loose.once the lid has been raised there are two screws on the inside front of the dryer that allow you to pull the front panel off.then you need to lift the back of the drum about an inch to remove it from the bearing holder then remove the drum.there will be four screws that you can get from the back of the dryer to remove the heating element.I hope this is helpful.let me know how things work for you if you eed any furthe help call me at 417-551-3436
Jan 22, 2010 | Frigidaire GLER642A Electric Dryer
Drum bearing
most dryers
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
maytag
  • unpug dryer
  • remove screws from bottom bend of front panel
  • lift front panel off
  • sent front panel aside
pull tensioner pully off bellt
pull belt off motor pulley
pull drum out forward
felts installed on drum edges can be examined for wear, as should roller support bearings
reassemble in reverse order
Different dryers may have: nylon glide plates, felt bearings rubber tired roller bearings or any combination of the above.
Local parts guy will have the parts as they are common to many dryer models.
Sep 06, 2008 | Dryers
Put together
1 Chrome Rail (for attachment to Worktop)
4 Self-Tapping Screws (to attach chrome rail)
1 CO2 Cylinder Support Stand
1 CO2 Cylinder (empty)
1 CO2 Regulator (high/low pressure gauges)
1 CO2 Air Line Hose (red)
2 CO2 Air Line Hose Connectors (black)
1 Beer Keg Coupler
1 Beer Tower Unit (complete with faucet, hose and wing nut)
1 Rubber Washer (to be installed inside wing nut)
1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
4 Machine Screws (to attach bayonet to beer tower)
1 Gasket (beer tower base)
1 Pull Handle (beer tower faucet)
1 Beer Keg Stand (required for 30 liter keg installations only)
1 Protective Plate (refrigerator cabinet floor)
2 Cantilever Wire Shelves (conversion to all refrigerator application)
1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
1 CO2 Air Line Hose Plug (located exterior rear cabinet)
1 Plastic Drip Tray (2 piece)
1. Remove Worktop: Using a Phillips Screwdriver, remove the
three screws located on the front underside edge of the
worktop and the three screws located at the rear (back)
side of the worktop.
See Fig's. 1 & 2
Remove the worktop from the cabinet and position the
worktop on top of the cabinet so that the front corners
are staggered across the front corners of the cabinet.
2. Installation of Top Rail: Attach the chrome rail to the work
top using four self-tapping screws from the underside of the
worktop through the pre-drilled holes. (attach the front ends
of the rail first)
3. Re-Install Wo r k t o p : Install the front of the worktop onto the
cabinet, then lower the rear side of the worktop over the
backside of the cabinet. Secure using the same screws
removed earlier. (the smaller screws at the front the larger
screws at the rear)
4. Installation of CO2 Cylinder Support: Install the cylinder
support onto the four studs located on the exterior back
wall of the cabinet. (no tools required) Align the holes in
the cylinder support with the studs and push down firmly.
See Fig. 3
5.
Installation of CO2 Cylinder: Install your " fully charged"
CO2 cylinder into the support stand. IMPORTANT NOTICE:
ALWAYS EXERCISE EXTREME CAUTION WHEN
HANDLING PRESSURIZED C02 CYLINDERS:
6. Installation of C02 Regulator:
Attach the CO2 Regulator to
the C02 cylinder by screwing the regulator nut onto cylinder
valve and tighten (snug) using an adjustable wrench.
7. Installation of C02 Air Line Hose to Regulator: Attach one
end of the (red) air line hose to the hose barb connection
on the CO2 regulator. Secure hose by using one of the two
(self locking) black plastic snap on clamps provided.
(use pliers to snap the clamp tight to assure that there are
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
CHI
See Fig's. 1 & 2
of the rail first)
screws at the rear)
See Fig. 3
5. Installation of CO2 Cylinder: Install your " fully charged"
6. Installation of C02 Regulator: Attach the CO2 Regulator to
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
LL'N TAP ACCESSORIES (included with this unit)
Jan 07, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Dryers Logo
96 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
