Question about Masterbuilt ESQ30B Smoker
I need to order a digital control panel kit - Masterbuilt ESQ30B Smoker
  • 8,197 Answers
Call this # they will get it for you.
1-800-489-1581
Good luck
Posted on Dec 16, 2008
I NEED THE 4 DIGIT CODE FOR A SHARP LCD TV ON THE GE UNIVERSAL REMOTE CONTROL
0286,0261. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 25, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have sony tv rm-GA010 controller.for lcd tv. but
Hi, you can order a new RRMCGA759WJSA from Replacement Remotes. or you can order the keypad repair kit from replacement remotes to fix your keypad problem. You need the solution that is sold in the kit to fix the rubber keypad for those buttons.
Nov 01, 2013 | Sharp GA759WJSA Remote Control...
My ge profile refrigerator temperature digital printout reads 999,888,777, etc. Is this a main control panel problem, thermostat or digital control itself?
This is just a bad display control board. You need to replace the actual display control board in order to correct the issue unfortunately. I'm not sure what shorted out both your main control and your display control board, but you will need to replace your display control now. hope this helps :)
Aug 04, 2013 | Refrigerators
After reseting the circuit braker the smoker did not come back on
Hi and welcome to FixYa, I am Kelly
Most likely the heater has failed.
The manual for the 20070106 is on this page:
http://www.masterbuilt.com/manuals.aspx
The element kit is PN: 9907090033 (Est. $45.00)
My thoughts are the element has shorted out. Before ordering read out the element with an ohm meter. Read each terminal to ground with the at least one wire disconnected. Then read the element end to end. You should read resistance end to end but NOT end to chassis.
That is just for the element. You said it did not come back on after resetting the CB. If the display is blank the control panel has failed: Contact Masterbuilt at 1.800.489.1581 (<-Only source)
MASTERBUILT Customer Service at 1-800-489-1581.
Control panel PN: 990050048 Digital Control Panel Kit
Something has caused the control panel to fail... if there is a chassis short some where in the unit you can have a brand new control panel fail. Inspect the wiring and components for signs of damage BEFORE replacing the control panel. Repair any wire damage found. Thee are only 2 components that use electricity; the control panel and the heater. Finding a wiring problem should be simple.
Thanks for choosing FixYa,
Kelly
Jul 24, 2011 | Masterbuilt 20070106 Electric Smoker
Amana ptac ac turn on runs short time on cool and go to fan mode warm air.
If this unit has the old style control with the knob instead of the digital control panel
then I would suspect this first. This is the first component to fail on these units. I have
replaced two already and the kit has good instructions and all components.
Takes approximately an hour to do and mount the new sensors. (The transformer is
hidden beneath the sheetmetal just below the control board). You should be able to order this kit through any appliance parts store for around 175 dollars versus almost
800 dollars for a new PTAC. Hope this is helpful.
Jun 26, 2011 | Amana PTH123B25AJ Heat Pump Air...
How do you mount a wood door on this dishwasher?? Archie
Bosch offers a kit for installing a wood panel in place of the normal outer door panel. Based on the limited amount of clearance between the bottom of the outer door panel and the toe panel, I would suggest using the kit offered from Bosch. You will also need the last 2 digits of the model # to get the correct kit. After the UC, there is a /, followed by a 2 digit number. This is also needed.
On a further note, you may also need stronger springs as a wood panel is much heavier than the normal outer panel. You do not want the door just falling open, it is a good way to bend the door hinges.
Apr 29, 2011 | Bosch SHV45M03UC Built-in Dishwasher
I need to purchas one maintenance kit for HP 5100 laserjet printer. what contents should be there in manitenance kit. I got no authorised information about this on hp site
To ensure optimum print quality, the printer will prompt you to perform printer maintenance every 150,000 pages. When the PERFORM PRINTER MAINTENANCE message appears on the control panel, you will need to purchase a printer maintenance kit and install the new parts. To check the number of pages the printer has printed, print a configuration page.
To print a configuration page:
1 Press [Menu] until INFORMATION MENU appears.
2 Press [Item] until PRINT CONFIGURATION appears.
3 Press [Select] to print the configuration page.
To order the printer maintenance kit, contact an HP authorized service or support provider. (See the telephone support flyer included with the printer.)
The kit includes:
fuser assembly
transfer roller
feed rollers
necessary instructions
For more information on installing the printer maintenance kit, see the instructions that accompany it.
Sep 07, 2009 | HP LaserJet 5100 Printer
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Haier Upgrade Kit
In one of my earlier post I posted the phone number where to order the board. However they were on back order so I got lucky an located the upgrade kit on Ebay. I'll post the part number for the kit and boards you need. TV-3940-01 is a kit that contains the following parts:
Control Board – TV-5210-39
Y-Sus – TV-5210-35
Z-Sus – TV-5210-37
EEprom (2006 version) - TV-2455-03
Apr 13, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Masterbuilt ESQ30B Smoker Logo
351 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
paulcarew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
