Question about Fuji Cameras
Have to reset camera every time i change the batteries why is the camera loosing its settings. is an internal battery failing
Found out there is a battery on the board inside the camera (inacssebile) so will have to put up with the problem for now
Posted on Oct 08, 2008
Why does changing the battery disable all the menu alterations and user settings I save on the p6000. Is there a way around this problem
Their is a small internal battery that holds the time inside the camera, Sounds like the internal battery is dead
Oct 14, 2014 | Nikon COOLPIX P6000 Digital Camera
Tip
Nikon Coolpix keep resetting Time and Date and menu settings.
Hi.
I am listing this tip for the Nikon Coolpix 995, but the tip is valid for all Nikon Coolpix models.
The Nikon cool pix settings are saved into an internal memory.
The internal memory is maintained by an internal rechargeable battery, that is recharged from the main Li-Ion battery.
If you leave your Nikon overnight with no main battery, or if the Li-Ion batteries have drained, then the internal battery will also drain , resetting the clock and other settings, saved on the internal memory. The camera may even drain in about 6 hours depending on the camera, normally it takes at least 12 hrs to drain the clock battery.
If the internal battery is resetting immediately, after you set the clock, or just after few minutes, then the clock battery must be replaced.
The camera must be disassembled completely to replace the battery located on one of the two main internal boards.
Nikon says that the clock battery loosing charge is normal. I quote what they say on the publication titled " The Nikon Guide to digital photography with Coolpix"
"Backup battery of the clock
The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset. Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
Original file: Download here
If the clock does not work at all, and is resetting immediately, even though the Li-Ion batteries are fully charged, then the best thing to do is calling Nikon, at the number listed on the owners manual, telling them that you did not do any improper use of the camera, and trying to get the fault repaired as factory defect. That is not always possible, and the decision depends on Nikon customer service.
See also: Nikon | Contacts
Ginko.
on Feb 05, 2010 | Nikon Coolpix 995 Digital Camera
Time/date won't retain
The camera's internal date/time "backup" battery is supposed to maintain the date/time for about 3 weeks with the camera turned off. If the camera is not used for a longer period, the date/time will need to be reset. If you are having to reset sooner than that, it is likely that the internal battery (not user replacable on most models) has failed.
Aug 20, 2014 | Canon PowerShot Cameras
Nikon 5000 indicate !"battery cannot be used. Choose battery designated for use in his camera" despite new battery
This is a guess, but the maintenance battery might have failed. There are actually two batteries in your camera. That is why when it is working properly and you remove the battery, you do not loose the time and all the other settings you have made. Although the non-user changeable battery typically lasts for up to a decade, but they can fail sooner. The camera must be opened up to make the change. You need to take the camera to a repairman or call Nikon USA for an RMA so they can change it for you.
Jul 26, 2013 | Nikon D5000 Digital Camera
Is there an internal battery for the time and the date?
Manual says: "After installing the batteries, the set-time/date message may appear on the monitor. The clock and calendar are set in section 3 of the setup menu (p. 18)."
In fact if you replace batteries really fast (in a minute or two) and time is reset the internal battery is probably exhausted/broken. You have to decide if it is worth of repairing.
My Z1 has 6 years and the clock does't forget time. Maybe next time i'll be surprised...
Mar 13, 2010 | Konica Minolta DiMAGE Z1 Digital Camera
I have a Fuji Finepix S7000 digital camera. I works fine, but, when the batteries get discharged, the camera looses all the "setup" info (date, time, etc...)... Is there an internal battery or something...
There is no internal battery. When the batteries become discharged or removed, the camera retains the date/time settings for about 24 hours. Most people have backup batteries fully charged so when one set is low in the camera, they can make the change quickly.
Feb 28, 2010 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
Sep 28, 2009 | Fuji FinePix S9000 Zoom Digital Camera
When battery is changed date and image size need resetting
Internal battery or capacitor may be bad and not holding charge to keep settings.
Oct 20, 2008 | Fuji FinePix F700 Digital Camera
Camera looses date & time setting
There is a cmos battery (or a memory battery) on the main circuit that like any battery wears out eventually. If you are familiar with repairing electronic circuits you can get the part from Olympus. There is no part number just "memory battery for C-740" will suffice. Your other two choices are to take the camera to a shop where they can do the kob for you. Don't let them sell you a complete new board, you don't need one. Not for this problem anyway. Or you can ignore the problem and reset the camera (or not)each time you change batteries.
Mar 29, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Cameras Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
