Question about Vintage Keeper 250 Plus Wine Cellar
Wine chiller (220 bottle fridge) has ice on vents, and struggles to hold temp @ 65 degrees...
I have a 220 bottle wine fridge, with a chiller inside. Everything seems to be working properly, fan kicks in, and blows somewhat cold air.. but i had to slowly increase the temp from 58 degrees all the way to 66... if i try to drop temp to 65 or evern lower, i get massive ice buildup on left corner of the front vent...
5 Suggested Answers
SOURCE: Koolspace 600 Problem
You'll need to replace the fan. The original fan bearings wear our after a couple of years. It's pretty simple to drill out the rivets and replace the fan. I suggest you replace all four with ball-bearing fan units.
Posted on Aug 01, 2009
ronald_kate_
  • 111 Answers
SOURCE: My Vintagekeeper Tuscany 220 wine fridge is making
Hello, this is a common problem when parts start to wear in the motor. They rattle and clang allover the place, depending on age of fridge you can get the motor replaced and regassed. Or depending on age it may be time to replace the fridge. I hope this is of some use.
Posted on Nov 04, 2009
  • 288 Answers
SOURCE: My kool space wine cellar is not holding temperature
has the cellar ever worked right in your home? These small refrigeration units basically move heat from a conditioned space to another space that is not objectionable such as your home where your central air system then moves the btu's. This being said, the cellar has a ventilation system that must pull in room air and push out the box air. these vents must be clean and clear of obstrucions to ensure proper performance by the equipment
Posted on Nov 27, 2009
imufo2
  • 3773 Answers
SOURCE: My Vintage keeper 220 will
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
For
extra help go here:
Thanks
for using fixya
Leo Ponder
imufo2
Posted on Aug 18, 2011
Is there such thing as a single bottle wine cooler?
Of course! There is a wide variety of single cooling systems for wine bottles. We don't drink a lot of wine, but when we have guests over I like to have the wine chilled properly. I prefer the stainless steel coolers, since the look more sleek and stylish.
http://www.amazon.com/Vinotemp-VT-CHILLER-SLVR-Bottle-Chiller/dp/B001NFX2QU
http://www.polyvore.com/danby_maitre_single-bottle_wine_chiller/thing?id=541026
Jul 31, 2012 | Furniture
My GE Profile Wine Center stopped cooling
Switch off, leave 5 mins then switch on again. Check display again.
Apr 22, 2012 | GE Profile FreeStanding Deluxe 29 Bottle...
Kitchen selectives rechargeable wine chiller bc-10r 8 minute chill
For the KITCHEN SELECTIVES WINE CHILLER...A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, plug in and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps! 8d55b92a-9870-497d-a9c6-7cda8d40c58a.jpg 11a83201-002b-4f0c-b811-810f4cf0046e.jpg
Dec 16, 2011 | Refrigerators
Thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Feb 01, 2009 | Waring Wine Chiller - Black
Vinotemp Wine Fridge Makes Noise, Doesn't Hold Temperature
Call the place you bought it and check on warranty .
Nov 15, 2017 | VinoTemp (VINO-24GN)
Need Owners Manual for Kitchen Selectives Wine Chiller (1 Bottle)
A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, turn on and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
Jan 16, 2009 | Kitchen Selectives CM-202 Coffee Maker
Does anyone know how to lower the temp below 45 degree's.
Dear friend,
ngfam at you service! happy to assist!
No they have no bypass!
How old is this wine cooler! MY ADVICE BUY ONE NEW!
It cost $241 to buy a new one at the site below!
NOT WORTH THE MONEY FOR A COMPRESSOR
Or model #HBCN05EBB FOR $249 96 BOTTLES CAPACITY
http://www.buy.com/prod/bc112g-30-bottle-freestanding-wine-
refrigerator/q/loc/63024/203111423.html
If the dishwasher is 10 years or older its not worth investing money tofix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 07, 2008 | Haier BC112G Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Vintage Keeper 250 Plus Wine Cellar Logo
Top Vintage Keeper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
