Question about Canon CanoScan LiDE 90 Flatbed Scanner
I have a CanoScan Lide 90 and the scanner bed is jamed and yes it is unlocked
  • 2 more comments
  • Anonymous Jan 27, 2009
    same
  • bobtoonman Jan 30, 2009
    Get another scanner. If Canon is not nice enough to post the answer to this problem then I would go with another brand entirely.
  • Anonymous Mar 02, 2009
    I have the same problem-- the scanning mechanism is jammed, but I have it unlocked.
  • Anonymous Mar 22, 2009
    Same problem here. There is a small piece of plastic that has broken off an is rattling around inside.
  • 3 Answers
I removed the glass, used a tissue towipe the inside of the center track, cleaned the glass and finally put some silicon spray on a Q-tip. The q-tip was almost dry, not dripping with the silicon. I ran it up and down both sides of the inside of the center track. I made sure it wasn't wet. then I used the Q-tip to clean the two bumps on both sides of the scanning wand. Put it back together and no problems since. DanInJapan
Posted on Sep 30, 2010
Had the same problem. take off the two framing pieces of plastic that run along the edges of the glass (they are stuck on with glue so use a knife). prize the glass out of the unit and check that you can move the scanning moving part up and down. remove any bits of plastic. test the moving parts by replacing the glass and scanning. mine seems to work fine now, fingers crossed. x
Posted on Jan 17, 2010
I tried to connect my Canoscan lide 90: when I try to scan: my computer doesn t seem to connect to the scanner: try the cable, connection and turn the scanner on. The connections seem to work... how do I...
Hi ,
The driver is probably missing . You can download and install it from here :http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide90#DriversAndSoftware
Best regards .
Aug 04, 2014 | Canon CanoScan LiDE 90 Flatbed Scanner
How do I determine what version is the twain driver that came with the canoscan LIDE 90?
You have to go into Control Panel, Device Manager, locate the scanner in there, right click Properties. From here just select the Driver tab, and there you've got the driver version and date.
You can get the latest driver from the Canon website.
Nov 19, 2010 | Canon CanoScan LiDE 90 Flatbed Scanner
I lost the set up CD ROM for the CanoScan Lide 90 and now the scanner doesn't work with my new computer
From this link you can select your operating system (Windows XP, Vista, Windows 7) and download the official drivers for your canon scanner. I assume that your scanner is lide 90, not lide 25 as there is different model at the headline and at your post.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 17, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE 25/LiDE 60 compatible with Windows 7?
Yes it is compatible with windwos 7.
Click here
Click on above link wait for 3 minute then select your os win7 then wait again then download driverr and patch update for it then install in computer then you can use it.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 02, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Canoscan Setup Utility CD-ROM missing
How can i install my canonscan 20 without the cd rom
Sep 07, 2008 | Office Equipment & Supplies
I have got a jamed scanner its loud and annoying
Move the lock switch back and forth and leave it in the unlocked position. The lock switch is located on the bottom of the scanner.
Apr 29, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon CanoScan LiDE 90 Flatbed Scanner Logo
563 people viewed this question
old marine
old marine
