SOURCE: 1/2 hp liftmaster closer stalls while closing in cold weather
Make sure your force settings are at least turned up to 5
SOURCE: Garage door will not open
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It is most likely stripped.
SOURCE: My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
SOURCE: Garage door will not close from remote or car.
wI have never heard of this problem. you have to hold the button on your wall in to close the door. no way this is not right something wrong with your board insid the opener. get help from a pro. I would love to see this been doing this for 20 years never heard of this.
SOURCE: Liftmaster 1/2 HP Garage Door opener won't open or Close
The shaft on these garage door motors are not direct drive systems. You'll have to open up the box to see what the actual problem is. I have had stuff like this happen where a gear just slipped out of place.
http://www.aaadooropeners.com/?gclid=CLH3wt628p8CFVZS2goduwSLYQ
Here is a link for a parts supplier. I don't know your model but it looks like most of the Liftmaster worm screw gears and drive gears are plastic so it's possible that one of them has cracked.
