Question about Maytag Kitchen Ranges
Older MER 30" smooth-top beeps, infrequent F1-code, bake set temperature and immediately shuts off. Manual breaker off, wait, then breaker on: does not fix. Pushing cancel does not fix. Stovetop elements all work.
    President:
  • Maytag Master
  • 2,651 Answers
F 1 is a fault within the control/clock assy,reccomned replacing the clock/ overlay that will resolve the issue
Posted on Oct 07, 2008
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
What does F1 error code mean when I put into bake?
Good Morning Friend, thank you for allowing me to assist you!
Typically error code F1 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
Jul 06, 2014 | Frigidaire Kitchen Ranges
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
Apr 21, 2014 | Whirlpool Ovens
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
How to set the oven timer?
To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
Mar 11, 2009 | Electrolux Kitchen Ranges
Getting an error code F1 and F3
F1,F3,F9 codes mean.
Electronic control has detected a fault condition. Turn the Temperature Control Knob to
OFF, and disconnect the power to the range. Wait 30 seconds and reconnect the power.
If fault recurs, disconnect the power and contact an authorized servicer.
Dec 16, 2008 | Frigidaire FEF366 Electric Kitchen Range
Bosch HES255U Covection bake slow to get up to temp.
My Bosch HES255U Freestanding Electric Range has been reading an error code of all "E's" or r 2 E E. I shut it off completely through the circuit breaker and allow it to reset. When I turn it back on, it starts to beep and shuts off.
Nov 01, 2008 | Bosch HES 232 / HES 236 Electric Kitchen...
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
Kitchen Ranges Logo
120 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
