Question about Fuji FinePix S5000 Digital Camera
Fuji finepix s5000 digital camera
When camera is on the screen is black, you view pictures but will not let you take pictures. will not turn off unless you take batteries out.
  • aaronpilot Oct 08, 2008
    when turned on to capture mode there is no image as if lense cover on. All the symbols and text come on so screen is working. You can also view previously taken photos ok. If you take photo it is all black.
  • bernie33330 Oct 21, 2008
    But only my screen is a purply colour and i cant take pictures
  • 593 Answers
Your CCD sensor has failed. Common digital problem that uses Sony sourced CCD chips. Proffesional factory replacement of CCD is only fix or buy another physicaly damaged unit and swap CCD boards. Not hard but intricate and time consuming.
Posted on Nov 16, 2008
I have a nikon coolpix s60 and when i go to view the pictures, the screen turns black and i cant turn the camera off unless i pull the battery
What name brand memory card do you use? I recently discovered myself that Nikon only supports SanDisk, Toshiba, Panasonic and Lexar. Try taking out the memory card and take pictures without the memory card inside the camera. If you can view the picture saved onto the camera memory then you will know that all you need is a new memory card, with one of the above mentioned name brands. Hope this helps.
Mar 01, 2011 | Nikon COOLPIX S60 Digital Camera
Black Screen
ok...open up the camera, remove battery and card for photos...then place battery in again, and turn on..see if that helps at all
Mar 09, 2008 | Nikon Coolpix S4 Digital Camera
I downloading my pictures to my pc. I went back to view them on camera and now some photos says picture error. it is a black screen and an orange exclamation point. please advise
once you have moved all the pictures to your computer make sure to disconnect your camera. no need to keep going back and forth.
on your camera try turning it off, pulling the battery out for a couple of minutes. insert battery. turn on. wait until it is fully on, navigate to view pictures.
if black screen is still present you might have zapped your camera while connecting and disconnecting the wire to the computer repeatedly.
repair is available http://www.teleplancamerarepair.com/
Aug 04, 2010 | Cameras
Snowy lcd screen and the eye view is also snowy
Test the camera by taking a picture and saving to the memory card. Then download it from the card to the computer and view it. If it is clear, the problem is in the playback system or the LCD.
Apr 12, 2010 | Fuji FinePix S5000 Digital Camera
I had Fuji S5000 for about 3 years. It worked fine. Now all sudden, I can't see any image when trying to take a picture. Both image through view finder and on LCD are just blank. Someone told me that a...
Hi
I have got an S5000 that I can still view previously taken pictures from the card, but when trying to take pictures the screen and view finder shows a peculiar distorted purple and green picture and any picture taken is just a green blur.
I contacted Fuji and they say they can repair it for £90 (about $120)
Nov 02, 2009 | Fuji FinePix S5000 Digital Camera
My camera is acting up
check the lens the lens might be closed if are open and hold for 5 seconds if it doesnt work take it to a specialist
Aug 07, 2009 | Olympus FE-170 Digital Camera
Display screen no longer works while taking pictures
Sounds like they accidentally pressed the DISP or DISPLAY button on the back of the camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time with the camera turned on.
Aug 01, 2009 | Canon PowerShot A630 Digital Camera
Can't see image in viewfinder or on lcd screen.
Bad CCD.
See if Fuji have Service Bulletin and will fix it for free under Lemon Law.
Mar 18, 2009 | Fuji FinePix S5000 Digital Camera
Pink viewfinder screen and pink photos
I am afraid your CCD is faulty.
No diy possible unless you can find a working CCD-chip.
Dec 20, 2008 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
305 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
