Question about Kodak Carousel 4600 Slide Projector
Autofocus I want to turn off the autofocus on a 4600 projector
  • 2,237 Answers
The only way to do that is disconnect the red, black and grey wires from the autofocus switch assembly, but you have to take the projector apart to get to it. if you do, it's on the bottom right side (facing the front of the projector) of the lens.
Posted on Jun 10, 2009
    Scholar:
  • 33 Answers
You could also just disconnect either of the wires going to the AF motor. That's all the AF on/off switch does on similar Ektagraphic models. THen if you change your mind, its easy to fix.
Posted on Aug 17, 2009
Dissamble 4600 projector
Check out the Service Manual posted at: http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf
There are 6 screws that fasten the bottom cover in place. Remove the Slide Tray, unplug the projector and turn the projector upside down. Remove the 6 screws. Hold the projector down on your workbench with one hand and pull up on the bottom cover with the other. Easiest place to get a grip is in the projection lens opening, but be careful not to bend and internal metal parts in the process! Also be careful because the power wires are fastened to the bottom cover and they are routed near the flat edge of the projector (opposite of the handle side) - pull apart slowly from the handle side. You may need a wide, flat-blade screwdriver to "coax" the bottom cover off. Good Luck !! Jim
Oct 16, 2011 | Kodak Carousel 4600 Slide Projector
Problems with using a 140 carousel on a Kodak 4600
There is nothing wrong with your slide trays. Your projector needs an adjustment to the cycle contact assembly. The constant cycle mode is a dead-giveaway. You need to take the projector to an Authorized Repair Dealer for this adjustment. Should be relatively quick - - it takes longer to get the case apart than to make the repair!
May 25, 2010 | Kodak Carousel 4600 Slide Projector
Tray will not advance
The problem you describe is most likely a broken spring on the lever that moves the tray forward or reverse. The repair requires dis-assembly of the projector and the slide change mechanism and adjustment after re-assembly. I recommend you contact a factory trained repair dealer to make the repair.
May 11, 2010 | Kodak Carousel 4600 Slide Projector
Carousel 4600. Dropping resistor is crumbling.
The dropping resistor is a 3 ohm, 30 watt resistor. It is available from: www.micro-tools.com
Jul 29, 2009 | Kodak Carousel 4600 Slide Projector
We received a donation of the 4600 projector but do not have a manual or power cord. How do we get these?
Internet. You can download an Owners Manual. For the power cord look online also or go to the store and buy one. Electronics shops usually have quite a bit of different kind of cords.
Mar 23, 2009 | Philips ProScreen 4600 Impact Multimedia...
Does anyone know how to turn OFF the auto focus on the Nikon Coolpix 4600??
Hello, After doing some research on the NIkon Coolpix 4600, it seems the camera is constantly doing the autofocus thing. IOW - it can't be turned off. Hope this helps.
Dec 03, 2008 | Nikon Coolpix 4600 Digital Camera
Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
How do I turn the power off (cool down)
yeah just hit the switch and it shuts down. there is no soft power down, which tends to lessen the life of the projector. Sorry man
Feb 23, 2008 | Philips ProScreen 4600 Impact Multimedia...
Slide projector autofocus constantly adjusting
My slide has the remote but remote is not working the projector i have is v5000Af
Jan 02, 2007 | Vivitar V5000AF Slide Projector
Kodak Carousel 4600 Slide Projector Logo
199 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
