Question about Amana Kitchen Ranges
I have a gas cooktop model AKS3640SS. There is spark and gas, but one burner is much slower to light than the other four. Burner is clean and firing like others; any idea on why and possible solution? Thanks
    Problem Solver:
  • 15 Answers
When it finally lights is there a big poof from a lot of gas? Is the spark on this burner as loud and bright as the others? Is it positioned where it is supposed to be? If not replace the igniter. You can test this out by robbing one of the other igniters and trying it in the problem burners spot.
Also you could pull that burner off the manifold where the burner tube slips over the gas outlet and check for any obstruction, like spilled and dried food, spider web in the oriface. If you get a big poof when it lights this is probably not the problem.
Posted on Oct 07, 2008
The stove part has five burners, 4 outer and one in the middle. One day the four outer burners stopped lighting, but the center one still does light. The four outer burners all still click when...
Look for obstructions or a buildup on the spark tip on each burner. I use a tooth pick to clean around them. Let the burner completely dry before trying to light it since water will give a shorter path to ground which will produce a smaller on no spark at the burner.
Jan 03, 2015 | Whirlpool GFG461LVS Stainless Steel Gas...
Westinghouse gas hob four burner only one igniting the other three only light with a match gas coming through but no spark
Clean the wires going to the ignitor of each burner, clean the burners as well. Chances are you have too much oil and dirt on them that is why your burners are not igniting.
Jan 27, 2014 | Cooktops
One of the burners does not light but it does have a spark at ignitor but it is not directed to burner port
Be certain the openings in the burner are free of debris. Boilovers can leave debris in the openings that will harden. Once this happens you cannot get the right mix of oxygen and gas for a flame to ignite. With the burner OFF, you can clean the openings gently with a toothpick to loosen the cooked on "gook." Then when you turn on the burner, the flame should burn off the residue and your range will be "cooking on all four burners!"
Nov 06, 2010 | Jenn-Air JGC8536 Gas Cooktop
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
Cleaned gas cooktop and spark ignitor started sparking on its own
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 07, 2010 | Whirlpool SCS3014LS Gas Cooktop
Bad ignitor needs replacement
it may just need cleaning at where it sparks to the burner if it is sparking back down the electrode then it is cracked . Some igniters pull out others have a screw that holds them in.
Oct 23, 2017 | Jenn-Air JGC9430ADS Gas Cooktop
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
One of four dials doesn't spark ignitors...
its a spark switch gone bad, 1 switch will turn on all four burner electrodes(its just easier 1 module)sometimes model dependant you can eplace justone switch, sometimes they come as a complete set
Feb 24, 2008 | GE 30 in.Profile JGP945 Gas Cooktop
Kitchen Ranges Logo
110 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
