Question about HP 5 TRAY FOR EXTRA HDD P4648-63019
How to print from extra tray - HP 5 TRAY FOR EXTRA HDD P4648-63019
  • 285 Answers
What exactly do you mean by that???
Posted on Oct 17, 2008
Fatal error 182
I expect you have an extra tray fitted. This error refers to this option. Turn the power off and lift the printer off the second tray .Now turn it back on and it should print ok. If so then throw away the optional 2nd tray as it has gone faulty.
May 12, 2016 | OKI C5650n LED Laser Printer
Mfc 7860dw will not print from paper tray
Check the paper level in tray 1 and keep the paper within the levels indicated by the arrows on the side. I had this same problem, and although the paper tray accommodates the extra paper, the printer obviously does not like it and defaults to the manual feed.
Mar 08, 2012 | Office Equipment & Supplies
HP Laserjet 4350 not recognizing addtional paper trays
Print a CONFIGURATION Page. On the 1st sheet/right side near the bottom will be a list of the trays that the printer detects. If all the trays are there, then your print drivers need to be reloaded. If the CONFIG page doesn't see the extra trays, then the tray may have a bad connector. You might want to try a COLD RESET.
May 12, 2010 | HP LaserJet 4350dtn Printer
How do I print 8-1/2" x 14" paper. I only have one 8-1/2" x 11" tray? Konica Minolta Magicolor 5430DL
On the 5430 DL there is an aux legal tray that can be purchased for legal printing. On a later successor the 5550 a manual feed option was included, however for the 5430 there is no option for printing legal without the extra tray being installed. On a side note, I have this tray and when not printing legal it lets me load an extra 500 sheets of letter paper which is very convenient when I need to print a bunch of sheets overnight.
Mar 15, 2010 | Konica Minolta magicolor 5430 DL Laser...
I have an hp 4200n that picks up an extra blank page when i print a menu map. the paper (blank page only gets up to the delivery assy past the fuser, no jam error). this happens when i print it from tray...
Hello, you must clean separation roller whit wet cloth or alcohol. Remove Tray 2, look for blue (usualy) cylinder feed rubber on it and clean Good luck. P.S You can clear paper feed roolers too (look at printer bottom after removing Tray 2) using same way!
Oct 15, 2009 | HP LaserJet 4200n Printer
How do I set OKI B4600 to print to top tray?
On the back tray where the paper comes out just push the extra piece in that helps to catch the paper until it clicks and it will automatically start coming out the top so you pages are in the order that you want them to be.
Oct 07, 2009 | OKI B4600 Digital Mono Printer - Black
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
Top Margin print cut
If you are using the bypass (tray 5), you need to move the limit of your tray from the normal position to 12" position.
Hope this help.
Nov 29, 2007 | Xerox DocuColor 12 Printer
Computers & Internet Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
