Question about Kenwood KDC-X590 CD Player
Kdc-x590 I have a refurbished kdc-x590 that first started distorting the sound (like a low battery radio) at no specific time and then the display willgo blank, now I get no sound at all and the only thing that goes on arethe 2 knob lights and the triangle light next to the att button. Whenthe SRC button is pressed all lights go out and no sound at all. Whatcan I do?? you can mail me at jaimecortes@hotmail.com Thank you for your cooperation
  • jaimecortes Oct 08, 2008
    Thank you for your reply:
    I have a voltmeter and soldering equipment. I will remove the stereo and connect it to a 12 volt source and give you the readings from the voltmeter, also. Should I check for any resistance, ohms, etc,on the speaker cables or any other ??
    Thank you
  • Dave DeGain
    Dave DeGain May 11, 2010
    Do you have some electronic skills such as soldering and a meter to check a few things? If so, you may be able to isolate the problem after checking a few things. If not, you really should just take it to a repair center to get it fixed. It sounds like it may have a couple of problems. The display out could be a series of surface mounted resistors on the main board that would need to be resoldered. The sound being distorted could be one of several different things. Are you using the RCA outputs of the radio for sound? If not, it could be the solder connections on the amplifier IC that are bad and would need to be resoldered or it could be a bad electronic volume control IC that needs to be replaced. If you are using the RCA outputs of the radio, it could be the amplifier that they get connected to. There are so many many different things that can cause these same symtoms that it will most likely require some good troubleshooting skills to really pin-point the causes. Please let me know your level of experience with electronics so I can determain if this is something that you can actually fix yourself. I will be perfectly honest with you about the possible causes and if they are something that you would be able to fix. You would also need a power supply to connect the radio on a test bench and be able to troubleshoot it. A multimeter is also a must have tool along with a soldering iron and solder, and also some solder wick to remove old solder with. This is definately not a problem that can be fixed without getting into the radio to check some things and most likely replace a few parts. Often, the most difficult part of the job is just figuring out what parts may be bad. If you have a multimeter, please check the voltage levels of the speaker wires coming from the harness on the radio. That would tell me if the amp IC inside the radio is bad or not. They all should be the same voltage, around 6 or 7 volts. There are 8 speaker wires, 2 for each channel. You will have a white pair, grey pair, green pair, and a purple pair. Check these voltages when the radio is turned on, even if all the lights go out you should still have that voltage there. This would at least be a starting point for me to help you.
    Dave
    President:
  • 624 Answers
The first thing to check would be the voltages on the speaker wires. They should be about 6.5 to 7 volts on each wire. Then check the surface mounted resistors on the front right side of the main board. Take out the CD deck and reflow the solder on them. Make sure you do this part with no power source connected. The surface mounted resistors have "2R7" on the top of them and are located in the right front as mentioned before, while looking at the unit from the front facing you. If you do not find the surface mounted resistors it could be that I am thinking of another model of Kenwood, but I am pretty sure they are also in this model as well. Use just a touch of solder on each side of the resistors, there are about 6 to 8 of them all connected in series. After that, reconnect the CD deck and connect the power source to the red and yellow wires and the black wire is your ground, connect that as well. The display should light up. Let me know what you come up with on the voltages of the speaker wires and if the display starts working again. I do not have access to my service manuals at this time, it may be about 2 weeks before I can get them. So I may not be able to get you completely fixed up until I can get my service manuals. A schematic is sometimes the most valuable tool when fixing electronics.
Dave
Posted on Oct 08, 2008
Change time
Hi here is user manual for your Kenwood KDC-X590.
Please download and review your manual via link below.
Kenwood KDC-590 User Manual
Nov 18, 2013 | Kenwood KDC-X590 CD Player
My kenwood KDC-X590 car stereo has no illumination but radio and cd player works. Is something burned out? HELP!!
there are about 8 - 10 surface mount resistors inside of the deck that need to be resoldered. They are on the front right of the board with the face toward you.
Jul 29, 2012 | Kenwood KDC-X590 CD Player
I can't get my Kenwood KDC-X590 out of demo mode. Help!
Press the [MENU] button for at least one second. Push the control knob toward [AM] or [FM] to select "DEMO." Press the control knob for two seconds to alternate between "DEMO ON" and "DEMO OFF."
If you need a manual you may download a copy here.
Jun 15, 2012 | Kenwood KDC-X590 CD Player
Display screen not working
Sounds like you might have a bad connection where the faceplate connects to the unit, or the faceplate is bad.
May 21, 2010 | Kenwood KDC-X590 CD Player
Kdc mp438u
it says protect meaning one of the speakers is shorted troubleshoot my speakers all were good put my old radio in everything worked put the kdc back in verified that the radio is bad took back to best buy interchange for a pioneer for about 60 more
Jul 03, 2008 | Kenwood KDC-X590 CD Player
Your KDC-X590
I have the kenwood x590. I have the lid open and the Cd mech out and looking straight down into the circuit board with the face pointed at me. Im looking at the right front corner and i see two two resistors labeled c20 and c18. To the right of those on the very edge of the board i have a row of chicklet looking things with number on top named 2r7. They are all named the same thing. Most of the number on my board starts with a C there are a few W's Q's.
Im guess the serial number on the board is j76-0169-02 x34-4150-10
Help.
Jun 20, 2008 | Kenwood KDC-X590 CD Player
Hey did u find the curcut # on the kenwood kdc-x590 if so pleas let us know !!! thanks for ur time
Are you talking about the circuit that lights the display? If so, you need to resolder the surface mount resistors in the front right corner on the top of the board. Front right while facing unit with top off and CD deck out. you will see a series of surface mount resistors and they all are connected in series. All of them need to be resoldered. That will make the display work again.
Jun 11, 2008 | Kenwood KDC-X590 CD Player
KCD-X590 is looking for a code that i never put in, and i bought the deck brand new
Method of clearing the programmable security
code (KDC-MP632U/X590)
1. While "– – – –" is being displayed, press [->> ] key for at
least 3 seconds while pressing [AUTO] or [TI] key.
This makes "– – – –" display disappear.
2. Using the remote controller, input "KCAR".
Press remote controller [5] key 2 times (Input for "K") and
then press [->> ] key.
Press remote controller [2] key 3 times (Input for "C") and
then press [ ->>] key.
Press remote controller [2] key once (Input for "A") and then
press [->> ] key.
Press remote controller [7] key 2 times (Input for "R") and
3. The security is released and the unit enters the STANDBY
mode.
4. If a wrong code is input, the unit goes into the Code Re-quest
mode.
Oct 14, 2007 | Kenwood KDC-X590 CD Player
Kenwood KDC-X590 ipod
Do you have a Ipod shuffle?
Is the deck on random?/shuffle?
Try pressing the small reset button on the deck, its small a small black button you would need a pencil tip to reset!
Hope it helps,
Don
Mar 16, 2007 | Kenwood KDC-X590 CD Player
Kenwood KDC-X590 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
