Question about Epson Stylus C48 InkJet Printer
Out of focus print
When we print it is slightly blurred and out of focus. Online check-in bar codes cannot be read a airports.
  • 68 Answers
Check what type of paper you are using if laser paper images bleed and look blurred use good quality injet paper.
Posted on Oct 07, 2008
I'm trying to print my boarding pass for tomorrows flight
YOu don't have to print it at home, if you have it on your phone and there is a bar code, that works. Or you can print it at the kiosk for that airline at the airport.
Mar 14, 2017 | Office Equipment & Supplies
Tip
How to print barcodes on plastic sheet
<p>Bar codes are symbols used by companies for the machines to read information about the products. Bar codes are typically used for identification and tracking purposes. When making your own products, and bar codes, you can print barcodes on plastic, but it is more difficult due to the plastic - cannot hold the ink. So it is important to follow these instructions to print barcodes on plastic. <br /> <p><br /> <p>1. Buy online card sheets or plastic from a local store office supply. This sheet is treated to work with most printers. <br /> <p><br /> <p>2. Create your bar code on the computer. Insert the sheet of plastic card printer and bar code on the plastic sheet. <br /> <p><br /> <p>3. Cut the UPC or shape and cut the plastic into the desired shape. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How to change settings on a barcode
<p>Barcodes can be printed symbols encoded information printed in black and white contain. You can use bar codes entering data into bar code - the generation of the image software and print barcode using a normal printer or a barcode printer. Printed bar codes are read by a barcode scanner that reflected light rays used to decipher the code. Bar codes may contain different information. You can change or a bar code can be adapted by entering the information reviewed in the bar code - generation software. <br /> <p><br /> <p>1. Access your favorite browser and go to barcode generator, barcode, bar code or soft (see Resources) can use a free barcode - generation software. <br /> <p><br /> <p>2. Most sites that offer bar code - generation software to present their application interface on their own pages. Enter the information reviewed or custom code in the space you want, and "Generate Barcode" button to click to create barcode images. <br /> <p><br /> <p>3. See the image of the barcode displayed on your computer, click on the image to pop-up menu to display. Click "Save Picture As" from the pop-up window, select the location where you want to save the image and click "Save" next window to save the image in the selected folder. <br /> <p><br /> <p>4. Connect the cable to patch your bar code scanner in its corresponding port on the back of your computer. Keep the scanner about six inches from the printed barcode, which focuses on the barcode and press the button to scan the bar code. Look at the revised data upload to your computer and check its accuracy. <br />
Printing using an Apple Airport Wireless network
I am not familiar with apple - However
Apple suggests resetting the printer system in the link below
https://support.apple.com/en-us/HT203159
Also driver may need updating which can be downloaded from brothers web site.
Other possibility I thought of is the port being used may not match the port that printing uses. port 515 TCP could be being blocked by a firewall of some kind or is not set up correctly.
https://support.apple.com/en-au/HT202944
Nov 12, 2015 | Apple AirPort Express (M9470Z/A) 802.11g/b...
My cam Canon SD40 just get a little blurred, how can i fix the resolution of this cam? is it in settings only?
This is not a problem with the camera's resolution.
Blurring can be caused by moving the camera during a shot, by poor focus, or by muck on the lens surface. Moving the camera is the most common.
Poor focus shouldn't happen with an autofocus digital camera, unless you are trying to take distance shots with the camera in macro mode. The lens would have to have grease or goo on it to affect focus, not just dust. You can check these things easily.
Try putting the camera on a tripod and see if shots taken that way are still blurred. If that fixes the problem, then you are not holding the camera still enough when shooting. Remember that digital cameras often have a slight delay between pressing the button and the picture being snapped, so train yourself to hold the camera still even after you press the shutter.
Oct 17, 2010 | Canon PowerShot SD40 Digital Camera
Just the blue on my rca projection tv is blurred. on the auto convergeance it says it cant read the sensor. on manual the cross hairs for the blue are oversized and blurred. i tryed tuning in the focus but...
Have you try adjusting your focus/screen drive controls to Tube R/G/B you have a focus/screen drive control block to adjust each Tube 3 controls ontop 3under them top ones are for Focus bottom is for screen drive.Red/Green/Blue Tubes.You might need to replace convergence IC, what is your Model number printed on back of TV?
Mar 24, 2010 | Televison & Video
Focus is blurred yet lense works in /out
check and see the min and max distance for focus in the manual. also slight movement can cause this also.
Oct 16, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
My RCA TV guide words is blurred but the
There are 2 things you try. go into menu to picture setup scroll down to sharpness,back this setting all the off. If this doesn't do it, go to back of the set on right hand side, if you can see focus slot adjust it slightly.
Sep 06, 2009 | RCA F25654BC 25" TV
Picture in View Finder perfectly clear, but out of focus
I would check IS(image stablization) setting and continous shooting setting to make sure these features are turned off. You want to experiment with different IS settings and definitely turn the continous shooting mode because the continouse mode may not focus 100% in order to shoot multiple shots. Hope this helps. -James. P.S. In my case it was too difficult to distinguish the quality of focus in the VF or LCD so you may not see the focus issue on them.
Apr 12, 2009 | Canon PowerShot S3 IS Digital Camera
Nikon D40 will not focus
on the right side of the view finder there is a little bar. Make sure it is all the way down. If it is in the up position then it will make the viewfinder, shouldn't make the images blurry though. Also make sure it is in AF not MF (auto focus and manual focus).
Oct 21, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Epson Stylus C48 InkJet Printer Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
