RCA RP3740A CLOCK RADIO CD PLAYER ALARM
HI I CANNOT SET THE TIME- CAN YOU PLEASE HELP ME? THX! NATALI
  • Anonymous Nov 03, 2008
    There is a combination of buttons that you need to push. I'm still trying to figure this out. Anyone want to share these instructions?
Just did it to check the process. Push button: Set (time/wake) Push it until the clock image appears on the upper left screen (it took me three times to push the button for this to happen). Let go of the Set button and press FWD button until it comes to the your time.
It worked for me. gotojo
Posted on Dec 11, 2008
I contacted RCA directly and they sent me the manual electronically. I have attached the link. If this does not work just email RCA, they responded within a few hours on the same day!! Hope this helps =)
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/fattach_get.php?p_sid=IjwDT8Ej&p_li=&p_accessibility=0&p_redirect=&p_id=224411&p_tbl=1&p_created=1248980100&p_file_id=33752
Posted on Jul 30, 2009
  • 62 Answers
Hold the set button, and then adjust minutes and hours accordingly, look for am/pm light too.
Posted on Dec 09, 2008
I purchased an RCA Radio/CD player, with the manual showing the numbers RP5605 and RP5605R on it. However, I cannot set the clock, alarm, etc. because everything in the manual's instructions is NOT in
To use the worry-free backup battery, get a 9V battery. Then look for the battery compartment on the bottom of the unit. Press the tab with your thumb and then lift the cover out and away. Plug in the battery and then replace the cover.
Press Wake Time once and use the forward/reverse buttons to set the alarm time. Then press Wake Mode repeatedly to toggle between the options of wake to radio, wake to CD, or wake to alarm. (Note the radio must be tuned to your desired station and a CD needs to be in the player for these to work).
The Smart Snooze means that pressing Snooze, forward, reverse, play or stop will turn off the alarm temporarily. (Pressing Off will prevent the alarm from sounding again today.)
The English version of the manual for the RP5605 clock radio is available here: http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/RP5605.pdf .
I hope this helps.
Dec 17, 2011 | RCA Audio Players & Recorders
I need a manual on how to set the time and alarms on fm/am cd clock radio model # rp 5600a
To set the time, press Set (furthest left button in the line including the Snooze) repeatedly until the clock icon shows on the display. Then press the FWD or REV buttons (on either side of the Snooze button) until you reach the current time. Press and hold to advance the time more rapidly. Press Set to save the time.
To set the alarm, press Set until Wake 1 or Wake 2 is shown on the display. Then follow the same directions as changing the time. Press WK1 or WK2 on the front of the clock to select the type of alarm.
The manual for the RCA RP5600 is available on the product page: http://www.rcaaudiovideo.com/audio/clockradios/?sku=RP5600 . See the Support/Manuals tab. The direct link to the manual is http://audiovox2.info/docs/common/RP5600/RP5600_OM.pdf .
I hope this helps.
Oct 22, 2011 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Hi i have a rca Clock Radio RP5435C i need to know how to set it.
Move the switch on the top back to either the clock symbol to set time or alarm 1 or 2 depending on which one you wish to set. On either side of the snooze button is a fwd and rev button. Push fwd to advance the time or rev to go back. If setting the alarm it will automatically turn the alarm on when you set it. To turn alarm on or off manually, push the button for the alarm you choose on the top rear right side.
Jul 19, 2010 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
How do you set the time and alarm on the RP5600A
Setting Clock
1. Press SET repeatedly until a clock icon
2. Press REV or FWD to set the clock
time. The time decrements or
increments will follow by a faster rate
when you press and hold the buttons.
AM or PM icon will also show beside
the time.
3. Press SET when finished.
Setting Wake Time
This unit allows two wake times to be set.
1. Press SET repeatedly on the top of the
unit until you see WAKE 1 or WAKE 2
flashes on the display.
2. Press REV or FWD to set the respective
wake time. The time decrements or
3. Press SET repeatedly until you see no
WAKE 1, WAKE 2 or icon the
display.
Selecting Wake Source
You may be woken up by radio, CD or alarm.
1. If your desired wake source is radio or
CD:
• Wake by radio - select an AM or FM
station (see directions on “Radio”).
• Wake by CD - insert a CD in the CD
compartment. If you want to be
woken up by a specific track on the
CD, press and hold wake up - cd
track
on the top of the unit and at the
same time press REV or FWD to select
a desired track.
2. Set a wake time (see above direction).
3. Press WK-1 or WK-2 repeatedly at the
front of the unit to select a waking
mode. Corresponding icon lights on
the front of the unit.
- Wake 1 by alarm
- Wake 1 by radio
- Wake 1 by CD
In case of Wake 2, “2” shows at the
centre of the icons.
Sep 30, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
ILOST MY MANUAL FOR THE RCA STEREO CD PLAYER/DIGITAL RADIO WITH NATURE SOUNDS .CAN YOU HELP ? Model # RCA RP3755D
All I wanted was the instruction booklet for this radio,and no I have not found one,and you're no help
Jan 28, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
RCA Clock Radio with CD player RP5620 How do i turn the alarm off so it will not sound at the same time every 24 hours?
1. Rotate the SELECTION KNOB to the WAKE MODE 1 or WAKE MODE 2 position.
2. Press the right or left arrow button to cycle through the wake modes until the alarm indicator on the display completely disappears.
Jan 14, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Rca clock radio with stero cd playera
Hold the center button on the back and then while holding push the button to the left to go backwards and the botton to the right to go forward
Oct 31, 2008 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Setting the time on my clock on radio Model # RP3755B
Well, I have an RCA clock radio/CD player and just figured it out. Press the "Time" button and hold it down while pressing the CD "Forward" button. Hope it works for you! Ron
Jul 03, 2008 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Alarm Clock
The manual can be downloaded from the RCA site:
http://support.rcaaudiovideo.com/manual.aspx?product=217
Oct 13, 2007 | RCA Mini CD/Radio Alarm Clock System -...
Changing time on RCA CD clock radio
UNPLUG!!! Wait 15 seconds. Plug in again, CLOCK will flash 12am.
Press "set" button ONCE.
Press Double Back Arrows |<< to go backward from Midnight
or
Press Double Forward Arrows |>> to go forward from Midnight
(Either press-hold the Double Arrows for quick minute-scroll or repeat-press Double Arrow for a slower minute-by-minute change.)
Sep 20, 2007 | RCA Radio Alarm Clock
457 people viewed this question
 Grubhead
Grubhead
