Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi VS-45609, picture is all red, green and blue vertical lines in center
I have a VS-45609 with a 1-2 error code, meaning no problem. The picture is entirely red, with a single vertical green line and a single vertical blue line in the center of the set. Can't adjust convergence and I already replaced the STK393-110 Convergence IC. I also checked all the fuses the the ohm meter and they seem to be good too.
  • 905 Answers
Check the resistors there
Posted on Oct 09, 2008
Mitsubishi tv model vs-45609 error code 1-2 what can i do
it was a self diagnostic, that was mean no error detected. just turn off and turn on the tv.
Oct 27, 2012 | Mitsubishi VS-45609 TV
The picture is clear but every thing has a blue shadow effect and all writing has the shadow about 2" under it.
Hi:
Your problem is the blue convergence IC has failed, there are two convergence IC's in this unit and I recommend you have both replaced because if one has failed the other is not far behind, better to do preventive measures now then later. One IC controls the Blue and the other controls the Red and Green convergence.
Jun 03, 2010 | Mitsubishi VS-45609 TV
Convergence problem
YES YOU CAN DO IT MANUALLY WITH THE SCR,IF IT WERE ME ID TRY DOING IT.THE FRONT SPEAKER GRILL COMES OFF,YOU CAN GO FROM THEREEWS,BUT YOU MAY SCREW IT UP MORE THAN BEFORE
May 21, 2009 | Mitsubishi VS-45609 TV
Mitsubishi VS-60609 60 in. I get sound but no picture. Just a red, green and blue lines in the middle of screen. Looks like a hour glass shape.
That sounds like a bad vertical circuit. Do you know how to use a meter and solder? If so we can troubleshoot otherwise you will need to call a repairman. A good repairman should run you $300-$500 to repair this. Let me know what you would like to do!
TIm Nolan
Sep 24, 2008 | Mitsubishi VS-60609 60" Rear Projection...
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS 45609 Blue Shadow On TV Picture
you need to replace the convergence IC STK393-110 you can get it as well as picture installation instructions as well as free online tech support at the link I posted very good prices
http://servicemanuals.vstore.ca/
May 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
IM HAVING A SLIGHT PROBLEM
You need service. Sounds like the convergence is out of adjustment. As the picture is formed by a tri- gun arrangement (one for each colour), if any of them is not correctly aligned, you will see shadows on any sharp line like text, or blurring on a picture. The shadow or blurring will often be one colour i e. red, blue or green.
Mar 27, 2008 | Mitsubishi VS-45609 TV
Mitsubushi vs4541 red,blue,green vertical lines no picture,very good sound
Try soldering the vertical output IC, sound without picture usually means vertical output is either defective or has bad solder joints. Does your on screen displays work when you press menu?
Mar 12, 2008 | Mitsubishi WS-48315 48" Rear Projection...
Blue, red and green ghosting, curves in picture
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 30, 2007 | Mitsubishi VS-45609 TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
226 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
