reset your eoc 3220 and put the default ip address is 192.168.1.254 bridge mode and ad mode ip is 192.168.1.253 and put your pc ip 192.168.1.10,12,14,16 and open the web page and browse the 192.168.1.254 or 192.168.1.253 put user name and password ok!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If you can connect to another, known-good EOC-3220 using the same serial cable and software setup, then your other EOC-3220 is probably just blown. It happens - I have several in a box in the workshop. :-(
There is no reset button on this model. To forcibly regain control of the configuration, you need a USB to serial cable, possibly a null modem adapter (depending on the serial cable), and a serial communication program like HyperTerminal or ZTerm for the Mac.
The manufacturer has incomprehensibly removed the detailed reset instructions from their website, but they can be found here:
http://www.keenansystems.com/engenius__senao_wifi_faq.htm
Look for the section titled "How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? "
Depending on the serial cable you have, you may need a modem (crossover) adapter between the cable and the EOC-3220. A good diagnostic is the following: with the EOC-3220 unplugged from power, connect your serial cable and make all the proper baud rate etc. settings in your serial communications program. When it is running, plug the EOC-3220 into power. If you don't see any garbage characters appear on your screen when you plug the power in, your comm program is probably not set up properly. If you see garbage characters but they are not immediately followed by good information from the EOC-3220, then you either need a null modem adapter inline, or you have a dead EOC-3220. If you've never communicated successfully with an EOC-3220 before over the serial channel, the only way to know if you have a dead one is to try again with a known-good one.
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
1 ) Check if IP address is the correct address of your Gateway. Check if you can ping. Be sure you have your Java enabled Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser. Be sure to remove any Java protection from your Browser. Check with user manual if IP address requires also a specific port number ( 8080 or other). Be sure to Connect Router using Lan cable 2) Change your PC IP setting to same subnet as your router Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway. 3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
You will always use a straight through. The default IP for this is 192.168.1.1 you also need to setup your PC with TCP\IP in order to log in. Go to network connections and double click on the connection for the NIC. high light internet protocol TCP\IP and click properties. then fill this in device IP 192.168.1.1 then PC IP 192.168.1.10 then 255.255.255.0 then hit OK. From there go to your browser and type http://192.168.1.1 there is no password or user name set the first time.
