Question about Garmin nuvi 200W GPS Receiver
Forget my password
Gps
  • 1 more comment
  • Anonymous Mar 23, 2009
    I'm Forget my password for nuvi 200
  • iizuu Mar 23, 2009
    i forgot my password is there a way to reset it
  • b_isita Oct 04, 2009
    FORGET MY PASSWORD
  • 2,200 Answers
The Garmin security lock consists of two parts - the PIN number/Password itself and your Safe Location. When you set the security up on the unit you have to enter a PIN of your choice and then set the security location.
This is the secret - if you can remember and bring your Garmin to the exact security location that you set up initially you can reactivate the unit from that location and then reset the PIN or turn the security feature off.
Because this PIN is written in non volatile memory there is no way to 'hack the unit' and it cannot simply be connected to a computer for example and reprogrammed by such a method.
Therefore - if you cannot remember your safe location you will have to send the unit back to Garmin for it to be reflashed by specialised equipment. Be aware they may also require a receipt as proof of ownership owing to stringent security on these units.
You may find this link useful as a reference point.
http://www.sciuridae.co.uk/understanding_garmin_lock.htm
Hope this helps. Please do rate this answer. Many Thanks.
Posted on Oct 04, 2009
    Brigadier General:
  • 4,090 Answers
Some GPS manufacturers provide a feature, which allows the GPS owner to assign a unlock access code or PIN to their GPS.
The PIN is designed to prevent your GPS from being used by an un-authorized user. It was also meant to be used a a deterrent to thieves, making the GPS useless if stolen.
When you set up the PIN, you will be asked to enter in a code. After you enter the last digit, you will be asked again for the code. This is to make sure that both entries match and verifies that the PIN that you requested will be the one written into memory.
Your PIN is written into non-volatile memory..... it's not a file that is accessible via USB communications between the GPS and a PC. You can't clear it by disconnecting the power or disconnecting the battery or letting the battery run down. There is no jumper or switch inside the GPS to reset it, so don't waste your time tearing your GPS apart in an attempt to clear it.
Now, after you set the PIN, you will be asked to set the "secure" location. This can be anywhere.... your work location, home, local gas station, school, etc. In order to set the secure location, your antenna must be up and you have to have a satellite lock. If you don't have a lock, the "set" key will be grayed out until you acquire a lock.
The secure location is your "back-up key" in case you forget your PIN. If you have forget your pin, all you have to do is physically go to the secure location. Make sure your antenna is up and that you have a satellite lock. When you are in the secure location, your GPS will NOT ask you for the PIN when you turn it on. You'll then be able to reach the main menu and change the PIN and secure location to something else if you desire.
If you have forgotten both the PIN and secure location, you are out of luck. You'll have to send your unit back to the manufacturer to have it unlocked. The manufacturer may charge you for this service.
Note: If you do send the unit back to the manufacturer to be unlocked and you are found not to be the original & rightful owner of the GPS and it's determined to be stolen, the manufacturer may contact law enforcement (they're policy on this is right on their website under FAQ's).
Posted on Aug 16, 2009
How to change password on garmin nuvi 1300?
First you have to know the password or know where the password was set. once the Garmin is unlocked you can go into the settings sscreen and change it. if you "forget" the password take the Garmin back to where you locked it and it should allow you to use it normally.
otherwise SOL. those don't unlock with any tools. even the Garmin Tech's cant help you without you sending them the GPS. Sweet revenge when a unit is stolen.
Jul 18, 2014 | Garmin nuvi 1300 Car GPS Receiver
I did forget the password?
Password for what? And what is the model of the GPS?
Jun 10, 2011 | GPS
Forgot my pin
Wedll if this is not a stolen GPS Then the matter is simple. Take it back to the exact coordinates that you set the pin in. Then you will be able to access the pin setup and reset it to a new password. Your only other choice is to send it to Garmin, but if it has been listed as stolen, then expect the cops! No one forgets their pin or fails to remember the instructions for setting and recovering their pin.
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “
Please rate my help++++Thanks for using FIXYA
May 23, 2010 | Garmin nuvi 260W GPS Receiver
Forget passwds
Take the unit to the location at which you first entered the password. The unit will unlock and you can change the password to something easier to remember.
Apr 25, 2010 | Garmin Nuvi 350 Car GPS Receiver
I lock my phone and forget my password for my garmin nuvi
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Jul 14, 2009 | Garmin nuvi 250 GPS Receiver
Lost password lock on Navigon 7100
forget it if you dont have the unlock code its useless and may even be hot!
Jul 05, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Forget my password
email garmin support and give them all ur info like serial number where u bought the unit and tell them u need to reset your password
Looking forward to helping u
Shaun
Nov 15, 2008 | Garmin StreetPilot C330 GPS Receiver
TomTom password lost / forgoten
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 28, 2008 | Tomtom ONE GPS Receiver
Hi its about my tom tom carnt remember my password
you might want to try the default passwords that came with it they maybe 123456, 1234, 0000, 000000 depending on how many numbers are required.
Jan 11, 2008 | Tomtom GO 910 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
280 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
