Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
Toshiba 52HM84 Ballast replacement help
I am getting similar symptoms from a bulb going out, it cycles through the green and red lights. Sound comes on but picture stays black. It keeps powering on and off again. Usually this happens about once a month but if I let it rest for about a day it works fine. Since it is beginning to happen more frequently now, I want to get it repaired. Hard to just throw away a $3,000 investment.
Anyway, after a lot of research most people tend to think it is a ballast problem. Since the part is only $60 that seems like a good place to start. Only problem is that I sure would like some tips or pointers to help me out replacing the ballast. Especially if anyone has a link to a good tutorial. I know my way around the inside of computers, but first time inside a TV.
Also wondering if you agree that this is probably a ballast issue. If it is the light engine, that would mean around $700 or more for repairs. BTW, the bulb is new and is not the problem.
  • 1 more comment
  • Jay Abed
    Jay Abed Nov 04, 2008
    hmmm.. I think you just answered my question. I just installed a new ballast. still having the same problem was wondering if I need to change the lamp.. though it looks good. but I guess you just answered my question. looks like it is a light engine problem!!
  • Anonymous Dec 23, 2008
    I have a 52 inch sony tv that i bought in 2003, and when i turn it on i see nothing but red, the tv is really nice, but i heard it was the bulb, the thing has three bulbs, has anyone fixed them your selves?
  • jschulst Feb 21, 2009
    I have the same issue, I replaced the bulb and work fine again. then I moved the tv to a different room and now i can't get the tv to come back on again. Where is the ballast located? email me at jschulst@verizon.net
It is very easy to fix/reolace the ballast in these sets. I just fixed the ballast in mine yesturday,by replacing a single resistor on the ballast board (the resistor is labled R3 on the ballast), Google "Toshiba ballast replacement" and there is a nice write up with pictures to guide you through it. If you can soulder you can fix it and save alot of money.
Posted on Dec 17, 2010
2 Suggested Answers
axeist
SOURCE: 52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
Posted on Jan 18, 2010
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
Green crt arcs ,no picture, sound ok
you either need a new bulb or your bulb is not installed correctly
Oct 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Sony 60" Grand Wega has Picture go BLACK and NO SOUNDS!!!
My Sony Wega KDF-55XS955 55" was going on for 1-2 minutes then going black with no sound and after a few minutes would come back on. After reading all the posts and talking with a repair guy I replaced the bulb and that fixed the problem.
Aug 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony 46" rear projection LCD HD - picture and sound go on and off
personally i would call a tv repairman out to fix the set.you can get alot of different opinions on here about what it may or may not be but the best thing to do is call a repaiman and let them fix it
Jan 27, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony Grand Wega 55" LCD ml # KDF-55WF655 goes protective shutdown
This is the lamp going bad. For some reason, it doesn't spit out that lamp error, it just keeps refiring the lamp and it just cycles forever. When the lamp totally fails, you will get the lamp led lit. Replace the lamp to resolve.
Dec 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Goes off and on
I replaced the lamp today in my KDF-60XS955 and it has worked perfectly since then. I purchased the lamp from sony, costs more but I got the correct part. Might be your problem since I had similar symtoms. 30 green flashes and picture/sound cycled off and on about every thirty seconds. Good luck. Chrismickey
Sep 12, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Keeps going black and coming back on - green light blinks
Our tv is about 2 1/2 yrs old and did the same thing we had to replace the bulb and bulb driver board this fixed the problem
Jan 27, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
1,571 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
