Question about Canon PIXMA iP4300 InkJet Photo Printer
Ip4300 fout 0x0000007f
Hi, Printer stopped and can't print anymore. Should I buy a new one?
error message is 0x0000007f.
Don't know what to do.
Thanks a million
K
  • Anonymous Mar 26, 2014
    does not print
Thanks for help.
I deleted the printer from my computer and removed all connecting cables of the printer
I reinstalled the printer by connecting my printer to the computer (after total shutdown of the printer).
Problem solved.
Greetings
SCout
Posted on Oct 08, 2008
Error code 311
The Error 311 indicates a communication error between the Mac and the printer. If you upgraded the Mac from Leopard to Snow Leopard, there could be older driver files for the iP4300 that are conflicting with the new driver. Therefore I would start your repair by trashing all of the Canon files.
The first step is to disconnect the USB cable between the printer and the Mac.
The next step is to delete the current printer queue for the iP4300. Open Print & Fax, select the iP4300 in the list and click the minus ( - ) button to remove the queue. You can now exit Print & Fax.
The third step is to remove the Canon files. These are located in HD > Library > Printer > Canon > BJPrinter. Select all the files inside this folder and trash them. Then empty the Trash and restart the Mac.
With the Mac restarted, you can now run the installer for the 10.6 driver you downloaded from the Canon web site. Ensure this driver is version 10.26.0.0.
Once the driver has been installed you can connect the iP4300 USB cable to the Mac again and open Print & Fax. If the install has worked, the printer should automatically appear in the Printers list (note that this can take several seconds). If the printer does not appear, click + to add and select the Default view. The iP4300 should appear in this view. Select it and click Add. You may get a prompt stating the printer is already installed. If so, cancel this install and try printing with the new iP4300 queue.
If the error message still occurs, then I would try another USB cable. They have been known to cause the 311 error.
Nov 09, 2015 | Office Equipment & Supplies
Although I have loaded my paper properly (i've been using this printer for over a year) it will not feed I get the error message that the paper is not loaded properly. I have tried to reload the paper and...
I will suggest you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see what happens. let me know if additional information is required.
Nov 28, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Hi there i have a problem with the Canon iP4300.
may be the printerisnt seeing the cartridge ,or its empty,.or the jets are blocked
Jun 27, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Error 1250 on PIXMA ip4300 printer. Despite open tray messae will not o away or allow printing to start.
the error message means there is something wrong with the printer and if the problem is not attended to, the error message will not go away.
In this case, the error message showing on your canon ip4300 is related to a door problem. It has something to do with the front door of your printer. I think the front door of your printer is closed of which is supposed to be opened.
So, the solution is to Open the paper output tray of your printer and the problem should be solved.
Good luck.
May 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Cannon Ip4300 - Orange light flashes on printer.
A possible paper jam has happen on the unit. Did you have an paper jam error before you have this problem?
You must clear any paper jam on the unit, check the unit for any stuck paper or object or check if there was misaligned parts inside.
Let me know for any clarifications.
Thank you for using fixya.
micro-
Dec 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
IP4300 print error message
Try holding the "resume" button (triangle in circle) for about 10 seconds for each cartridge.
If that doesn't work, go to a refill shop and ask if they have a re-setter for your cartridges. Most shops do.
The re-setter gives new serial numbers to the cartridges, so the printer thinks you have put in new ones. Or you can buy one.
In 99%, when the printer tells you that one of the cartridges is empty, it's actually not. The chip is the one that tells the printer when to stop printing. If you bypass the chip, you can continue printing.
Hope that helps!
Sep 12, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
89 people viewed this question
old marine
old marine
