Question about Cartier Watches
Authentic or not
HI my name is jonathan I have a older model cartier watch model geneve 18kg argent plaque or g20m it has these numbers on the back of the watch17080343 I was wondering if this is an authentic model cartier and if so what year was it made and what would be an approximate price on it
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Is this cartier watch authentic
Nobody can tell you this by the number only exept Cartier itself.
Follow this link, enter details and ask questions directly to Cartier:
http://www.cartier.com/en_na/Cartier
Rate me, please.
Posted on Mar 19, 2009
  • 183 Answers
SOURCE: Fake or not
Generally you have to open the watch to see the movement but a lot of fakes are plain workmanship flaws.
A real Cartier will not be made from base metal. It will be made from stainless steel or precious metal.
A real Cartier will most likely be built with screws in the band instead of cotter pins.
When you pull the crown to set there will be no play in the set lever. In other words when you spin it, it will begin to turn the hand immediately and there will be a slight resistance. It will not feel loose.
As stated, the best way to tell is to look at the movement. Cartier uses a high grade Swiss movement most likely marked ETA.
Posted on Sep 17, 2009
gemineye61
  • 831 Answers
SOURCE: I have a cartier watch and want to know if it is
  • Visit an authorized Cartier watch dealer at a high-end jewelry store. Use a jeweler's loupe to inspect the Cartier logo, the dial, the hour, minute and second hands, color, case back and the movement, which is the small electronic or mechanical device that runs the watch. Also examine the bracelet or strap for future comparisons of Cartiers at other dealers. Obtain a copy of the Cartier sales brochure or catalog and read it.
  • Inspect the movement by asking the seller to remove the case back to view it. It will be engraved with the Cartier name. If the seller balks at the request, don't buy the watch. The seller may have something to hide, according to Spotcounterfeits.co.uk.
  • Consider the heft of the Cartier if you are considering purchasing a watch from an independent seller. Knockoff Cartiers are considerably lighter than the genuine article because they are made with cheap materials. Examine the Cartier logo to see if it's spelled correctly. Knockoffs usually originate from non-English speaking countries where English is not the primary language and workmanship is poor.
  • Drop a tiny bit of water on the crystal. Cartiers feature a sapphire glass crystal, in which the water beads on contact. If the water smears, the crystal is a cheap imitation.
  • Examine the Cartier trademark polished cabochon gemstone on the crown. The stone should be set firmly in the crown but not glued on. Use a jeweler's loupe to look for traces of glue.
  • Examine the Cartier logo of twin Cs on the case back, dial and strap buckle. The logos should be gracefully produced with no rough stamping.
  • Posted on Sep 01, 2010
    gemineye61
    • 831 Answers
  • Examine the Cartier logo of twin Cs on the case back, dial and strap buckle. The logos should be gracefully produced with no rough stamping..
    • 2501 Answers
    SOURCE: complete description of cartier argent pettite
    Go to http://www.cartier.co.uk/#/show-me/timepieces/(collections)/tank_francaise/(properties_id)/1653 and select the model you want and click on it to go to the detailed description of that model.
    Posted on Dec 22, 2010
    I have a cartier watch 925 argent plaque or g20m swiss 17 050343 and i want to know it's original or not
    I took my watch to a jeweller and he gave me the info I needed at no charge. You could do the same. I wanted to know if it was worth what I paid.
    Oct 13, 2016 | Cartier Watches
    Cartier Model Numbers
    From what I can tell, the major differences between the watches:
    W20011C4: Quartz Movement (battery)
    W20058C4: Automatic Movement
    W20011C4: Case Thickness - 6.7mm
    W20058C4: Case Thickness - 8.3mm
    W20011C4: Date at 3:00 position
    W20058C4: Date at 6:00 position
    W20011C4: Newer Model
    W20058C4: Older Model
    The W20058C4 is the older watch and will be reflected in the price, as compared to the W20011C4. However, it does have an automatic movement which is much more desirable. It really depends on your taste/budget/preference.
    Be very careful about purchasing a secondhand timepiece. There are so many fakes out there. Purchase one from a recognized Cartier dealer or one that guarantees the authenticity of the watch. Do not be lured in by prices that seem too good to be true.
    Nov 07, 2013 | Cartier Santos W20011C4 Wrist Watch
    I bought a watch from the charity shop today it is marked on the back with cartier paris 925 plaque or g20m swiss 17050343 can any one tell me about it
    I keep saying the same thing on this board; call Cartier and describe the watch to them, you could also take digital photos of it & email them. They are always going to be your best resource for vintage or any other type Cartier watches. You can Google their number.
    Having said that, your watch seems like it may be a REPLICA ( meaning, fake, I'm sorry) 'Cartier' Argent, which may be worth around $250. It is not a real Cartier. There's no way even a charity shop would sell an authentic Cartier for anything under $1,000. I am sorry to disappoint you, and if you don't feel you can count on my say-so, you are welcome to call Cartier & verify what I've said.
    Nov 01, 2012 | Cartier Tank Watches
    I want to buy a Cartier lighter but I want to make sure it,s real. How do I look up the serial number?
    To look up the steel ligter serial number is very easy ,I specialize in buying and selling Cartier watches. I've seen fakes with all the correct marks and a serial number, but that doesn't mean they are legitimate. If the watch was registered by Cartier when it was sold or if it has been sent in to Cartier for service Cartier will be able to verify it is authentic, but be aware that if the watch was not originally sold in North America or was not registered when sold (fairly common) it can still be authentic. Some sellers offer the Cartier quartz model for sale and only state that the watch has a quartz movement, but fail to mention if it has a Cartier quartz movement. If it has a replacement movement in it the watch is technically authentic, but not original and is not worth as much as one with an original or a genuine Cartier replacement movement. The biggest mistake I've seen amateur Cartier buyers make is using the Cartier micro-script signature on the Roman numeral to verify authenticity. Indeed this is a good indicator, but not the best indicator as there were many Cartier watches produced prior to the technology required to make the micro-script possible and not all Cartier watches have Roman numerals for the dial to have the micro-script signature. Furthermore, the micro-script is not always located at the same place and if the dial has been refinished it may not appear at all. Another common problem is actually caused by language differences, i.e. "all original versus "authentic". A watch can be authentic without being all original. Unless someone has owned the watch since it was new and it has never left their sight it is impossible for them to state the watch is "all original" as a part could have been replaced at some point in time -- even without their knowledge. Your best bet is to buy from a reputable seller even if you have to pay slightly more money. -- Cartier_Specialist
    May 08, 2012 | Watches
    I have a mens wrist watch by cartier with numbers on the back .Iwould like to know if these numbers are authentic or fake
    For authenticity you have to contact Cartier (cartier.ch) or show your watch to a decent watchmaker.
    Feb 13, 2011 | Watches
    I have a cartier watch and want to know if it is real. The back says Cartier. Plaque org 20m and swiss # 4 05626. On the inside on the back it has a # 15705. On the back face of the watch it says cartier...
  • Sep 01, 2010 | Cartier Tank Solo Watch
    Rate me, please.
    Mar 19, 2009 | Cartier Tank Francaise W51001Q3 Wrist...
    Is this a genuine Cartier serial number
    is the watch real is it says cartier r1628 water resistant swiss made 2301 cc708177 ???
    Apr 13, 2008 | Watches
    Fake or not
    Oct 13, 2007 | Timex E Tide Temperature Compass Watch...
    Watches Logo
    110 people viewed this question
    Top Cartier Watches Experts
    k24674
    Jimmy Accardi
    Are you a Cartier Watch Expert? Answer questions, earn points and help others
