Question about Frigidaire ATF6000ES Front Load Washer
Not spin Washer will not spin at end of cycle
  • 7 more comments
  • Anonymous Oct 09, 2008
    My machine will go through the entire wash cycle but it will not spin.
  • Anonymous Oct 13, 2008
    i have the same problem
  • Anonymous Nov 26, 2008
    will not spin at end of cycle, and i also try different sized loads!! problem with the motor??
  • Anonymous Nov 27, 2008
    Our front load washer will not spin, and our clothes are completely wet. I had just completed a load and started another and this problem occured.
  • Anonymous Nov 28, 2008
    I am having the same problem.
  • nforeman Dec 01, 2008
    The front washer will not spin and leaves behind a few inches of water in the tub.
  • jwfifield Jan 02, 2009
    I am having the same issue. I did 4 loads of laundry and on the last one, the clothes were sopping wet. Tried spin only cycle, washer will not spin at all. Have unplugged it and removed back panel, belt is fine, motor working, will not spin. Load was not a small load, was a load of jeans.
  • Anonymous Jan 22, 2009
    will not spin
  • bamboo7 Feb 06, 2009
    My washer is 3 1/2 years old. It will not spin or drain at the end of the cycle. For the fourth time in two weeks, a repairman came to check it, machine ran well while he was here, and for the fourth time, did not spin the next load of laundry after he left. I'm going to mention the door latch when I call tomorrow. Let's hope it's that simple.
    Problem Solver:
  • 10 Answers
I had the same issue. Found the solution on this website and am posting to help anyone else with this problem. The problem is the door latch assembly. There are 2 connectors in there that burn out over time. My washer is 2 years old and this went out yesterday. You can find the part (#131763245) at your local appliance part supplier for around $50. Or you can find the part on repairclinic.com
Posted on Jan 02, 2009
  • 750 Answers
Hello elvis 1964
welcome
Hello harley1964dm
Welcome
You said, Washer will not spin at end of cycle
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Huuum
Please remember to leave a rating
Posted on Oct 13, 2008
Maytag Neptune MAH-1 front load washer won't spin in some cycles I use often. it spins at the end of the cycle and in cycles I do not use often. it spins in the spin cycle when I run that cycle
sounds like the timer is not advancing is certain cycles? timers have contact points that can burn and seize up sticking close and not allowing the next cycle to move
Mar 16, 2015 | Maytag Washing Machines
Washer squeals at end of spin cycle
The manufacturer recommends you tilt back the washer and spray some penetrating oil into and around the brake package to stop the squeal.
Jan 18, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Washer does not spin at the end of the cycle.
check that you do not have the crease gaurd or rinse hold button depressed? does it spin at all can you put it on a spin cycle with clothes in and no clothes in?
Jul 23, 2009 | Frigidaire GLTF2940F Front Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Feb 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
End of cycle spin
my washer will not drain unless if the boot is squeezed.
Aug 17, 2008 | Frigidaire GLTR1670A Front Load Washer
Will not spin dry at the end of the wash cycle
Check the brushes in the motor. This is a normal problem.
Jan 22, 2008 | Zanussi W1242W Front Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
120 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
