Vcr playback sound interruptions
I replaced the TV a few months ago. Before that I had no playback problems. The TV is a Dynex, DXR24TV, the VCR is a Panasonic PV-9400.
During the normal play mode sound intermittently drops and returns for no apparent reason. When I place the VCR in Action or Program mode where there is no video, the sound is uninterrupted.
There is the occassional picture rolling in addition to the lost sound. All of these problems make VCR viewing impossible.
I have no idea how to solve the problems. Can you help?
Keith Donald
ksdonald@bellsouth.net
    Master:
  • 505 Answers
Please get the VCR check by any local technician. Since the sound is dropping intermittently it is a hardware issue
Posted on Oct 08, 2008
How do you change a sound card on a dynex tv?
The sound PCB is not separate it is part of a larger board. I do not suggest the cost as it may not fix the problem. Just replace the TV.
Aug 30, 2016 | Dynex DX-LCD37 TV
I have a Denon AVR 790 for about 8 months now. Hooked up a combo DVD VCR player using the red/yello/white cables. It worked fine for about 6 months. Now I cannot get the DVD or VCR to play. I get sound,...
If dvd combo player is only video source connected with Denon AVR 790 then unplug yellow video wire from Denon and plug it directly in TV input, now video signal will go directly to tv and sound will come from Denon AVR 790 speakers during dvd playback.
This is simple bypass that wont effect surround sound of dvd playback.
Let me know if you have additional question.
Thanks.
Oct 20, 2010 | Denon Audio Players & Recorders
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
Dynex DX-R20TV flashes blue screen
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Apr 11, 2017 | Dynex DXR24TV 24" TV
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
3-4 switch
1. Set tv to channel 4
2. insert a pre-recorded tape into vcr.
3.press play once to start playback.
4. after a few seconds press play on the vcr for 3 sec you will see a playback picture.
when a picture doesn't appear on the tv screen repeat step 4.
5. press stop to stop playback.
Mar 16, 2008 | Sanyo VWM-950 VHS VCR
Sound Problem
If you are feeding the VCR signal into the antenna connector,then you could have a problem with the sound circuit drifting off frequency. If you are feeding the VCR signal into an "A-V" jack then you could have a problem with the audio amplifier inside your set. The circuit board would have to be tested to determine where the exact problem is located. Stargazer
Jan 08, 2007 | Daewoo DTQ-27S2FC 27" TV
Unable to record or playback VCR tapes
All you can do by yourself unlesss you are a tech. Is run a head cleaner tape through it. It sound like a dirty head to me. Here is something a lot of people do not know, The video head and the audio head in a VCR are two separate heads. thats why you can loose picture and not sound. Best taken apart and cleaned manually with rubbing alchol but not advisable if you are not experienced due to high voltage and if cleaning improperly you can damage the unit worse. Good Luck
Nov 25, 2006 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
