Question about Hitachi 60SBX78B 60" Rear Projection Television
Tv won't turn on.
When I turn it on, n'thing happen. I open the back, and saw that when I plug it in, three or four green dios lights come on and than go out.
  • Hitachi Master
  • 3,459 Answers
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Posted on Nov 02, 2008
My Tv will not turn on the red light comes on then go's off Hitachi model# 60sbx78b
Posted on Jan 23, 2009
My Sharp Aquos TV went off whilst we were watching it and won't come back on. The red power light flashes twice per second and the green OCD light flashes three times every second. Is there a re
Tries tv unplug replug the tv back about an hour later,might resetting the tv back factory setting and should work again.Still have the problems,the main board it is shorted and dead require changing.The main board that board were the incoming broadcasting signal wire plug into it.U have some basic machanic skills like take things a parts and putting it back together again.Should have no problems change this board at all..Tried websites like Shopjimmy.com,eBay.com to buy a refurbish main board for the replacement.
Feb 24, 2013 | Sharp Aquos Televison & Video
Green light blinks three times but T.V won't power on
Power supply probably fried. You will have to take the TV apart to test.
Jun 23, 2012 | Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Sony Bravia KDL-55EX500 flashing green and yellow light, an won't turn on. Any suggestions?
you guys are going to love me. lol. i figured it out at least for mine. $ )
1.start by unplugging the tv and everything plugged into it(make sure the only thing plugged into the tv is the power cord).
2. next plug in the usb flash drive with the update or a compatible version of the firmware.
3. now while holding down the up arrow button on the tv remote, plug in the tv and keep holding the up arrow while pressing and holding the power button on the side on the tv until you see the light on the tv go from solid green to solid red and yellow flashing lights. once you see this just sit back and wait a few min for it to force the update and it should turn on when its done.
let me know if this works for you as well or if you need any clarification. also know that step three is a pain to do alone and must be all done within a short period of time preferably at the same time.
Oct 16, 2011 | Sony Televison & Video
I have an emerson 32in flat screen tv i turn it on the green light flashes for a second then shuts off before the picture even comes up
Not promiseing that this will fix yours but I had a similar problem with a different TV I unplugged for three or four minutes and plugged back in and worked ok after that so give that a try and see if it helps.
Thumbs UP if it did!!
Jun 21, 2011 | Televison & Video
I have an Olevia 242tfhd television that just stopped working. The blue light was on and when I pressed it- it wouldn't turn on and the blue light went off. I unplugged it for a day and when I plugged it...
Same happened with my Olevia 540-B11. You can probably find the details of how to disassemble the TV somewhere online. The problem is poor stress-relief on the cables that plug into the secondary (low voltage) side of the power circuit board (PCB). Once the back is removed you'll find the PCB on the left side with three cables connected to the very top of the board. These cables plug into four clips, 3 horizontal clips side-by-side at the top and one vertical clip on the left side. Unplug these cables, remove the PCB and re-solder the sockets (there are approximately 40 solder points on the back of the board). Reassemble your TV and it'll work just fine.
Dec 15, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
ONLY LAMP LIGHT FLASHING WHEN PLUGGED IN, WON'T START, NOYHING HAPPENS WHEN YOU HIT THE POWER BUTTON.
make sure the lamp cover is in good and the screw is snug just had mine open and only thing that it does is red light flash and nothing on screen......unplug power and try it then plug it back in about three or four minutes later.....hope that helps
Nov 15, 2010 | Hitachi 50VS69 50" Projection HDTV
TV won't turn on.
The problem is the digital main board if you can get ashop to order it for you its easy to replace yourself four screws and three or four plug in connectors.
Jun 30, 2008 | Sylvania LC320SS8 32 in. LCD Television
Televison & Video Logo
213 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
