Question about Belkin (F5D7230-4) Router (587009)
F5D7230-4 wired laptop wont connect
Hi I have a desk top wired to this router and it works fine along with the main one, but I have tried to connect my work laptop which again is not wireless and it wont connect properly. It says its connected but I cant get email or internet access. Is this a router configuration prob or my laptop? Please can you help?
  • Anonymous Oct 14, 2008
    i got a belkin wireless G router i can't get it to work on my new laptop can u help mere to put it together thank u...
  • 905 Answers
Also if you have wep setup in your belkin utility's you will have to give the laptop the next code provided in your belkin utility's , sometimes it won't restart the router after settings changes
on mine ,the same as yours , sometimes I have to unplug the router then plug back in for my wireless connection to my laptop to work ( only happened a few times so far,had it for a year now)
Posted on Oct 07, 2008
  • jason Oct 09, 2008
    in your belkin settings
    The DHCP server function makes setting up a network very easy by assigning IP addresses to each computer on the network. The DHCP Server can be turned off if necessary. Turning off the DHCP server will require you to manually set a Static IP address in each computer on your network. The IP pool is the range of IP addresses set aside for dynamic assignment to the computers on your network. The default is 2-100 (99 computers) if you want to change this number, you can by entering a new starting and ending IP address and clicking on "Apply Changes".
    also check the DHCP client list to see if the other computer is there
  • 87 Answers
It is not a router configuration problem its a laptop problem in the configuration. Do you have the network card installed if so try a reinstall. if not go to your network wizard and set it back up .
I have a wireless network. the desk top s connected via an ethernet cable. When he desk top computer in another room is connected wirelessly, I cannot connect wirelessly with my laptop or vice versa. ...
Since already you have a computer which is working fine using a wired connection , please click here to reset the wireless settings of your router and to connect to your all other wireless computer.
Thanks in advance!
With regards,
Prema.
Jan 06, 2011 | Buffalo Technology WHR-G54S Wireless...
Problem with laptop computer connecting to wireless network router since it crashed on startup of windows and did a disk check and repair. The laptop always connected before this. Their is also a desk top...
Since ur Computer has Crashed the Settings for Wireless N/w might have been Deleted
All u have to do is to Once again Scan for Wireless on ur Laptop
Connect to ur Wireless N/w with ur Wireless Password
And U will be online Wireless
If u are Not aware of Wireless INFO, Check Settings on Router from ur MAIN Computer
All the Best
Oct 01, 2010 | Computers & Internet
Belkin router
Hi Friend,
When you are tring to connect in wireless it will ask for password,please follow the below steps and get the security key of your Router
Step 1:Connect the Modem to Router (in the Port named Modem) and take another ethernet cable abd connect one end to the Router(in the port named Wired) and other end to any one of your computer
Step 2:Open an internet explorer and type 192.168.2.1 and click on Enter button in the keyboard
Step 3:Now you will be able to see the belkin router setup page
Step 4:On your left hand side click on Security,it will prompt for a login password,leave it blank and click on Submit.
Step 5: In this page you will be able to see the security key or PassPharse,please make a note of it and type the same when its asking for security key
Regards,
Aysaam
Jun 07, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
We have a new desk top and now our laptop wont connect with internet...we have a belkin router that worked fine before
You will need to check the wireless settings of the router is there any computer connected to the router ? If yes then you can open the router set up page on that computer. Router set up page is the page where you can check all the wireless settings of the router.
Mar 03, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Inability to connect to Internet
The easiest solution would be to use an ethernet connection. A second problem is probably on most cable modems you can either use a USB connection OR an ethernet connection you cannoot use both at the same time.
Dec 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Internect connecting
If the laptop was connecting wirelessly before and you didn't change the wireless security key on the router during your troubleshooting steps with the ISP then it should just reconnect. If it doesn't reconnect you should probably delete the wireless profile that's saved and try connecting again. When you delete the wireless profile you will have to enter the security key again. Make sure you have this information handy.
If you are uncertain what the wireless security key is use your desktop that is physically connected to the router to log into the router and reset the security key.
To log onto the router you need to know the routers IP Address. You can obtain that information through the following:
START MENU
RUN
Type CMD
Click OK
Type IPCONFIG
Hit Enter
Look for the default gateway. The default gateway is the IP Address of the router. By default the IP is 192.168.1.1.
Type whatever IP Address you discovered into the address bar of your web browser (Internet Explorer for most) and hit enter.
You will be prompted for a login. If you didn't change the default login information to the router it should be a blank username and the word: admin - as the password.
Navigate to the wireless settings and reset the security key.
From your laptop key in the new network key.
Hope this helps.
MO
Jul 18, 2008 | Linksys Wireless-G WRT54GS Router...
LAN Not Connecting
Hi I just wrote the problem with the three desk tops . But my laptop wireless are working fine.I forgot to leave my email.It's c.a.foster@quadro.net Thanks from Denver07
May 15, 2008 | Belkin (F5D72304F5D7000) Router
I'm a little confused how to install this router I just bought. Model #wrt54g2. do I put the cd into my desk top which is already connected to the internet or do I install the cd in the new laptop I just...
Hi sheena -Is your desk top hooked up throgh the router? If not, plug your modem into the wan port on the router. The router should have come with a couple of short cables, most likely blue and yellow. Use the blue to connect your modem to your router. You can check the manual just to be sure. Use the ethernet cable that had been connecting your desk top to your modem, and plug into one of the wired ports on the router. I imagine you'll be using wireless for your laptop. Make sure that it is on. Put the cd in your desk top and run from there. Follow the directions. If you need more help just add a comment and I'll be glad to assist you further. If this solves your probleb PLEASE rate this as fixed. Remember. Need help? Just holler Sheena.
Jeff
May 04, 2008 | Computers & Internet
Wireless router dropping then disappeared
If other wireless hosts are connecting to the wireless router with no problem, and the windows laptop intermittently connects, then this seems to indicate a problem with the wireless card in your windows laptop. If the device is still under warranty, it should not be a problem to contact the laptop vendor and have it replaced.
Sep 20, 2006 | Zyxel (91-004-361002) Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
108 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
