Question about Brother Office Equipment & Supplies
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
I changed the drum today. The fax continues to give a message, "change drum soon". The print quality has not gotten any better either. I took the toner out and shook the cartridge, replaced it and made a copy and still cannot see the print that well.
  • 1 more comment
  • gbrown778 Oct 07, 2008
    To Ekse
    The model is Intellifax 4750e
  • gbrown778 Oct 08, 2008
    Ekse, thank you so much for your input. Our fax is the Intellifax 4750e, business class laser fax, super G3. I opened the cover, pressed options and it said, "no original", online. Its still telling me to change drum, although it has a new drum. Any other ideas?
    Ekse,
    Thank you, Thank you, Thank you!!!!!!! It worked.
    Now, do you have a suggestion for the bad print quality? The machine has a new cartridge of toner in it.
    Genius:
  • 3,422 Answers
Hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Posted on Oct 07, 2008
  • Robert Lee
    Robert Lee May 14, 2014
    Model MFC-7460DN, I had to press the clear key instead of the option key. Otherwise this worked great.
    Scholar:
  • 116 Answers
Your drum unit which you have replaced have still not detected by the fax machine.you have to reset the machine when you change the drum.or replace the drum and insert the new drum in the OFF mode so it will not know if any thing changed in the machine and mostly should work as normal.
please keep updated.
  • 1,029 Answers
this happens when the drum nears its end of life This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
After changing the Drum, open front cover and press "clear" then press "1" to reset.
Note
    Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability.
    If you are using a genuine Brother drum and toner and after following this procedure the unit continues to show "CHANGE DRUM SOON", your machine may require service. Please contact the Customer Service Center.
  • Starnley Johnwells
    Starnley Johnwells Oct 07, 2008
    hope this helps.goodluck and godbless
    Genius:
  • 1,124 Answers
Take out the drum, clean all contacts and all the inner of the printer with spray air (buttane), and try inserting the cartridge again. If this will not fix your problem your printer must be serviced.
  • Brother Master
  • 19,396 Answers
That means that you need to replace the drumkit, post the exact model to get replacement .
  • Brother Master
  • 13,433 Answers
After the drum replacement, the unit might need to be reset, can you post the model so I can look into this?
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
6.Press Options.
To confirm you are installing a new drum, press 1.
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
The printer screen shows change parts and on the wlan computers connected to it says that the drum end soon and that panics me a lot as i paid a lot for this damn computer
Did you recently replace the drum and the warning is unexpected?
Why does the message "Drum End Soon" continue to appear on the LCD after I replaced the drum?
Description:
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  1. Press Menu on the Control Panel.
  2. Press the Up or Down Arrow key to select Machine Info..
  3. Press OK.
  4. Press the Up or Down Arrow key to select Reset Menu.
  5. Press OK.
  6. Press the Up or Down Arrow key to select Drum.
  7. Press OK.
  8. Press 1 to reset the drum unit counter.
You can use this procedure to reset a drum in order to continue to use up the remaining 'life' of the drum; recognizing that you will need to replace the drum when you start having print quality issues.
You may find this site very useful.
Trust this is helpful. Please vote.
Dec 31, 2010 | Brother MFC-9840CDW Laser Printer
My all-in-one printer keeps telling me that I need to change the drum soon. I bought a new drum inserted it into the printer and now I can't print anything. Plus, it is still telling me that I need to...
Note
    Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brother limited warranty does not apply to any problem that is caused by the use of unauthorized third party drum units, toner cartridges or toner.
May 01, 2010 | Brother MFC 7420 All-In-One Laser Printer
Change drum soon message won't go away after changing drum and toner. what do I need to do?
35YRTECH, aren't you being a wee bit flippant? I just changed my drum, had the same problem, and no where in mys instructions does it tell me how to inform the printer that I did reset the drum.
Anyway, here's how to do it (form the brother web site)
  • This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
    2. Press the Clear/Back key.
    3. Press 1 to reset.
    4. Close the front cover, pressing firmly on each side until they click into place.
Jan 07, 2010 | Brother Office Equipment & Supplies
FAX SAYS TO CHANGE THE DRUM SOON
Open the front couver as if you are about to change the drum unit. With the couver still open, press the options button for a while and in the display will apear a message asking if you want to change the drum unit. Choise the yes option and close the front couver. GOOD LUCK.
Nov 13, 2008 | Brother IntelliFax-2820 Laser Fax
Continous 'change drum soon' message after I change the drum.
5750e fax machine: To reset the drum counter follow the instructions listed below :
Get the message to appear in the LED
2. Remove and Re-insert Drum/Toner unit
3. Press the CLEAR key.
4. Press 1 to reset.
5. Close the front cover, pressing firmly on each side until they click
into place.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007572&Sympt=Why+does+the+message+CHANGE+DRUM+SOON+continue+to+appear+on+the+LCD+display+after+I+replaced+the+drum%3f&Model=58&ProductGroup=2&Keyword=Change%20drum%20soon%20message&ProductID=PPF5750e
Jul 08, 2008 | Brother Office Equipment & Supplies
Ricoh 3310L Fax machine - 'Time to change PCU'
You need a new drum. Photoconducter unit. Cost about 140.00 I sell them or you can shop on EBAY
Aug 10, 2007 | Ricoh 3310Le Fax Machine, FAX3310Le...
3,771 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
