Question about Philips Audio Players & Recorders
No wi-fi connection between centre station,restored factory settings,powered up station first,side by side,no walls,no router nearby,system brand new,does it really take this long to connect?what am i doing wrong?
  • 8 more comments
  • CARBODIES Oct 07, 2008
    WACS7500
    ALL SETTINGS RESTORED STILL SAME WACS7500 NO WI FI CONNECTION
    WACS7500 NO WI FI CONNECTION BEEN THROUGH MANUAL STEP BY STEP,RESTORED SETTINGS ON BOTH,THEY ARE SIDE BY SIDE NO THICK WALLS NO NEARBY ROUTER,JUST SWITCHED BOTH OFF LEFT FOR 5 MINUTES,POWERED CENTRE UP FIRST RESTORED SETTINGS ON BOTH,LETS SEE,IF NOT THEN WHAT ELSE CAN I DO?
    WACS7500 BRAND NEW THIS SHOULD NOT NEED FIRMWARE UPDATES IT SHOULD CONNECT TO STATION,EVERY ONE KEEPS TELLING ME WHAT I HAVE DONE ALREADY
    I HAVE A MANUAL I HAVE READ IT,LOOKING AT IT ON A SCREEN WILLNOT HELP
    POWERED UP CENTRE RESTORED SETTINGS,THEN POWERED UP STATION RESTORED SETTINGS,BOTH SHOW LANGUAGE,CHOSE ENGLISH ON CENTRE GOES INTO INSTALLATION MODE,CHOSE ENGLISH ON CENTRE GOES INTO INSTALLLATION MODE,CENTRE SEARCHING FOR STATION 0 FOUND,STATION SEARCHING FOR CENTRE
    OK HOW DO I CHECK FIRMWARE,I WENT TO SETTINGS CLICKED ON FIRMWARE,IT SAID ABORTING?DO ICONNECT IT TO MY LAPTOP WITH THE EARTHNET CABLE?I DONT KNOW.
    installed WADM THEN IT ASKS ME TO RUN AS AN ADMINISTRATOR PROGRAMME?HOW DO I DO THAT?
    Sergeant:
    Champion:
  • 435 Answers
Hi, If you want to run WADM, logout and login as administrator and run it   or right click the wadm icon and select run as administrator.
if it doesnt detect the Wifi Center,  goto  Control Panel> Administrative Tools> Servicesand disable "SSDP Discovery Service" and try WADM again...
Meanwhile let me go throught manual and see what might have gone wrong.
Posted on Oct 07, 2008
  • Karthik P Oct 07, 2008
    I THINK I FOUND IT !!!
    Just follow these steps:
    1. To reset Center, check the Center is switched on
    2. Press MENU on the Center (or on the remote control)
    3. Press  to select Settings and then press  to enter
    4. Press  to select Restore settings and then press  to enter
    5. Press  to select Yes. The set is rebooted. Language selection screen appears
    6. Select your desired language: English, Français, Español, Nederlands, Italiano or Deutsch
    7. The Center enters Installation Mode
    The following step is very important.
    1. While this goes on, remove the power plug of Station and then connect them to the power supply again
    2. Press MENU on the Station (or on the remote control)
    3. Press  to select Installation Mode and then press  to enter
    4. The Wi-Fi connection is being re-established
    5. Press STOP  on Center when all the Station(s) are found
    Found it in philips.com
    It should work now.
    Sorry about the missing pics,
    Its just up, down and right arrow pics.
    Basically you need to get into installation mode in Center
    When its searching, you need to disconnect and then connect the Station and go into its installation mode.
    and they connect to each other.
  • 63 Answers
You may consider connecting that device directly to the router for you to set up the connection properly the proceed to the wireless connection.
    Scholar:
  • 158 Answers
Y cant you try with a homenetwork as per the instructions given in the manual.
instead of direct center/ station  communication
if thats gonna work fine then i don think there will be a prob with independant center/ station wifi communication
    Genius:
  • 1,011 Answers
Sir,
Click this link for manual to try it yourself....
http://www.p4c.philips.com/files/w/wacs7500_12/wacs7500_12_qsg_aen.pdf
thanks
good luck
    Sergeant:
    Champion:
  • 334 Answers
Also if witch doesnt work great idea also like rascal says cheak switch take direct network cable if it has it dl latest firmware updates for it and software
  • 2 more comments
  • nick helpap
    nick helpap Oct 07, 2008
    run cable direct to it get all latest drivers k
  • nick helpap
    thats not true i dont care how new it is u nee dto go cheak for firmware ther come out so often on vista new systems once mo sumtimes wh knows how long your new ideam benn sitting in box do full windows updates 1st please ok u wnat it fixed do what i say cheak
  • nick helpap
    dl driver on notbook 1st ok for your firmware drive for it then yes connect it with cable ok
  • nick helpap
    then change my rating to least helpfull u have top get firmware updated on it cheak windows all that also for custum updates drivers ect get all latest stuff in fixs patches helps u know
    Sergeant:
  • 320 Answers
Go through the manual once.. Please click on the below link or copy the URL and paste it in web browser.. Follow the steps..
You deinstall everything and start from first.. See if there is any software for activating the device... Hopefully it should work.. any other queries, please let e know..
Thank you....
    Genius:
  • 1,913 Answers
Check ping of gateway.if u get ping thats all.
if u not get
reset your router and all other device factory defaults.also check alll cable connection.check power supply and earthin working properly.
  • kishor khatri
    kishor khatri Oct 07, 2008
    yes connect it to your laptop with ethernet cablerthen acess it with http://192.168.1.1
    then set dhcp enable in it then check in your laptop u get ping yahoo.com or not.
    Scholar:
  • 116 Answers
Try doing it again.from step 1.as what you did earler.
or either its the problem of frequency.
  • mastermind10 Oct 07, 2008
    http://www.e-bowl.co.uk/products/5003.ht...
    just click this link and check out for the connections and what to do if you dont receive stations or missing stations.
    this will definately help it not please keep all of us experts updated.
    also read the question---answers for your solution which are given below in the link after the demo of the device.
    please click the link which i had given and read the instructions it will be solved.
  • Philips Master
  • 13,433 Answers
Can you post the model of your philips? so I can find out how its supposed to be done. in your model.
  • 2 more comments
  • Ekse Oct 07, 2008
    Heres the user manual
    https://www.p4c.philips.com/files/w/wacs...
    see page 22 for set up wifi connection between centre and station.
    You need to power up the centre first then station.
  • Ekse Oct 07, 2008
    let me know how that goes..
  • Ekse Oct 07, 2008
    have you tried to power up the centre first then station?
  • Ekse Oct 07, 2008
    You need the power up the CENTRE first then STATION.
    Let me know how that goes.
    Thanks,
    Ekse
    Guru:
  • 1,894 Answers
First of all tell us what is the model
toshiba needs a switch to turn ON
  • dewan nafees ahmed Oct 07, 2008
    in toshiba laptops there is a wifi switch near volume scroll
    only if you switch it ON you get the wifi service started.
    after that if needed you will have to create a new wireless connection also
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Wireless router configuration
If you don't already have a wireless network, you can use an AirPort base station to create one. To configure an AirPort base station, you connect the Ethernet connection to the WAN port on the base station. In turn, the base station creates a Wi-Fi (wireless) connection to the Internet. Consult the documentation for your AirPort base station for more information on how to set up your wireless connection. Once you have a Wi-Fi network available, use these steps to tell your Mac to join it:
  1. Click the Wi-Fi menu icon airport_symbol.png and select your Wi-Fi network from the list of available networks.
  2. If prompted, enter the password for your Wi-Fi network.
  3. Check "Remember this network" to have your Mac automatically join your home network.
Mar 03, 2014 | ASUS Us Rtn53 Dual Band Wireless Router...
My iphone does not work on w.i.f.i. or 3g, my friend has a camera set up and can only view the pictures on my iphone when my router is switched on
You can manipulate iPhone's settings to refresh flaky network connections, or reinstate lost ones, while physically moving closer to a Wi-Fi base station when needed. You can also improve your Wi-Fi base station or wifi router performance to overcome typical Wi-Fi issues.
Jun 16, 2012 | Computers & Internet
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
The router is blinking a yellow light
Here are some of the more common reasons that the status light may blink amber:
  • The Wi-Fi base station has not yet been configured because it is new.
  • The Wi-Fi base station has been reset.
  • A new firmware update is available for the Wi-Fi base station.
  • No IP address is available for the Wi-Fi base station.
  • A Wi-Fi base station in Extended Mode is out-of-network Wi-Fi range of a primary Wi-Fi base station.
  • The WAN Ethernet cable is unplugged from the Wi-Fi base station.
  • The Wi-Fi base station lacks a path to the Internet (or local router).
  • Internet access may be temporarily unavailable from your Internet Service Provider (ISP).
  • Your AirPort Time Capsule has detected that the internal hard drive has reported a SMART error, and is failing (This requires firmware 7.5.2, and AirPort Utility 5.5.2).
Feb 10, 2011 | Apple AirPort Extreme Router
Can i connect belkin to belkin through dsl modem and how
Yes, you can connect:
DSL modem WAN/Internet port on Belkin #1
LAN/network port on Belkin #1 WAN/Internet port on Belkin #2
LAN/network port on Belkin #2 your computer
If the two Belkins are in different rooms, and there are more than one computer in the room with Belkin #2, it makes sense to run ONE (not MANY) Ethernet cables from Belkin #1 to Belkin #2.
Nov 19, 2010 | Belkin Basic Wireless Router
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
WACS700 NOT CONNECTING TO STATION
Mine did the same, the station was trying to connect on channel 1 wi-fi where the centre was on channel 11, check under information and wi-fi for both. I then did a restore on the station, put both into installation mode and they found each other after a few mins.
Hope this helps
Jul 08, 2008 | Philips WACS700 Shelf System
233 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
