Question about Bosch WFMC 3200 Front Load Washer
Flashing E:04 The machine beeps that it is finished but it is not and the E:04 is flashing.  When I did get the door open once for the first load, it had not been in spin mode. Do not know how to get it to spin dry.  Then did a second load with water in the tub and got the same problem - flashing E:04. Help. Please.
  • 1 more comment
  • herschelt Oct 18, 2008
    Same problem.
  • Anonymous Oct 28, 2008
    Same problem...E:04 and drain not clogged, use little amount of he detergent.
  • kpshah0 Jan 18, 2009
    I have the same problem, and I was able to fix it using the solution below.
Further on the solution provided on Oct. 28th.
The circular cover is on the front, below the door on the 3200UC. Use an unfolded large paper clip or in my case a large safety pin and push in where there is a small hole. Rotate the cover slightly and it opens. Once you get that open, there is a valve to unscrew. Be sure to have towels or sponges around as this will drain what ever water is left in the drum. Unscrew the cover only a little until water starts to leak out. Once it's drained, remove the valve cover completely. There is then another white plastic piece that you can gently pry out with a flat head screw driver. Once that's out, you'll be at the main drain. In my case there was an infant sock blocking the drain. I removed that and the machine works like a charm again.
Hope the details help a bit. Thanks for the original solution!
Posted on Nov 30, 2008
HELP!! My Bosch washer is humming but not draining the water after 10 minutes of washing. Error E04 appears but no blockage on the hose. Where else should I look? Thank you all in advance.
Posted on Oct 18, 2008
  • herschelt Oct 28, 2008
    I was able to fix the problem on my Bosch WFMC3200US. There is a circular cover that can be remove, (remove carefully cuz I damaged mine), and behind the cover is a cap that you can unscrew ( a gas-cap type). Once you unscrew the cap, you can have access to the drainage that comes from the laundry to the outtake valve. Clean any hairs and other debris that maybe preventing the flow of the water.
The door is locked and the Finished/Spin and Wash Lights are all flashing alone with a beeping tone. This is in ALL wash modes except off.
my machine did that when stuck on spin cycie all i did was unpluged it for a few seconds and pluged it back in and it let me start all over again and open the door
Aug 31, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washing machine has stopped and a symbol of a key is flashing. Door will not open and no program will work
The key and flashing = child lock.
To get rid of this - turn to normal setting, press the power switch and keep pressing for several seconds. The symbol should disappear and the beeping should stop.
Nov 27, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
Jul 19, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Will not drain ....E-04 is flashing...this was a test load,just finished opening front access plug and draining w/ shop vac,could not find any thing down there to cause a blockage.....?????
Your pump is plugged. There is a round 'door' on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in (just a little), and you can rotate the door clockwise, the door will come out and you can get to the problem.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. (We used a pile of towels to catch this). The Black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog.Remove it, screw the black connector back in, and the washer ran fine.
After a couple of loads (to make sure there was no leak) put the door back on...and rotate . And thats it your problem is fixed
Apr 08, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Flashing F what is this
This is usually too much detergent or severely out of balance load. Unplug the washer, this will allow you to open the door to re-balance or eliminate very heavy items from the drum. Close door re-plug and restart machine. If this doesn't do the trick repeat the unplug and reset the dial to rinse/spin to clear excess detergent once finished restart normal wash cycle.
Jul 21, 2009 | Whirlpool WTW6400SW Top Load Washer
Indesit wil 103 door won't open...
Welcome to Fixya.
Try holding the Start/cancel button in for at least 2 seconds.
If there is another lamp flashing at the same time as the door lamp, then you will have to call an engineer.
Dec 18, 2008 | Indesit W 123 Front Load Washer
Washer flashing fault codes
truthfully, i think you have a malfunctioning board.if all parameters are correct and unit is washing while beeping is taking place. represents board.
May 16, 2007 | Frigidaire GLTR1670A Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
235 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
