Tv problem blue screen only and asking 4 a key can anyone help
  • blaze56 Oct 07, 2008
    wharfedale M2126 (key 4 blue screen 3 digit number)
  • blaze56 Oct 08, 2008
    NICE 1 RODY3 PLOBLEM SORTED NICE 1 MAN UR THE MAN
  • 68 Answers
Pin code required when TV has been unplugged from mains supply. In the instruction book there is usually a default pin code depending what make the set is. some use 5555 but need the make of tv set. If you have forgotten the pin code the default should still work.
Posted on Oct 07, 2008
  • rody3 Oct 07, 2008
    try this press (input)the pp button on the remote 3 times press ok and it should be ok.then go into setup/function/lock and disable lock.
I purchased a component cable (rectangular plug I think called VGA plugs into female left side laptop toward the back and red, blue and green RCA type jacks for LG TV.
Look for a Function Key (fn) on your laptop for activating the VGA external monitor.
If your fn button is blue (for example) all of the keys on your laptop that are activated when you hold down the fn button will have an option in blue. Look for a blue icon on a key that roughly looks like a monitor or two monitors.
With everything hooked up, press and hold the fn key, then tap the corresponding key to turn on the external monitor.
Having said that... the cable you are describing has a VGA (blue 15 pin connector) that plugs onto the VGA jack of your laptop and splits that signal into a set of component RCA plugs. Its critical how you plug these into the correct place on your LG TV component connections. I know such adapter cables exist but I've never seen one work.
Sep 06, 2017 | Acer Computers & Internet
Unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Jul 20, 2008 | Apex Digital AT2702 27" TV
Pc connected to tv, but only a blue screen shows
Up on your F KEYS is a SYMBOL that looks like a small TV Monitor... HOLD DOWN THE FN (function) key and tap the F key with the monitor.
1. On one click the screen on the computer will go black and you will see the screen now on the TV,
2. On a second click the computer monitor will come back on, and you will also have the TV screen.
4. On a third click you will kill the TV display and end up where you started, with the display on the Computer Monitor only..
Kindly,
Jim
Dec 10, 2009 | Gateway MT3705 Notebook
Blue pixels taking over
The light engine has dust in it.
There are a few good TV Techs that are now trying to clean the Light Engine rather than replace it at a $1500 cost. There is hope, but ask the Tech if he does this job first otherwise there is no hope unless you chump out the big bucks.
Aug 04, 2009 | Televison & Video
The picture on my LTV-19w3 WH tv just shows a blue, black, or green screen with about a 4" sq. plaid patch in the upper right hand corner. Sometimes the sounds works other times it does not. Can anyone...
While the TV is on do the following:
1. Press the "Right Arrow" button on the remote.
2. Press the "Left Arrow" button on the remote
3. press the number keys in order, 1-9
I believe you are in the TV's service menu and the Blue/Green/Black are just test patters. If so, pressing these keys will eventually change the pattern..
Get to the main page of the service menu and press the [power] button on the remote.
Jun 16, 2009 | Westinghouse LTV-19W3 19 in. LCD...
Ctc television locked by remote
I came across it by sheer fluke I held the Number1 key and the very last key on my remote and held them together for about 10 seconds, this deactivated the lock that was on the screen. I asked a few technicians but, u know people just don't want to help anymore. So i hope that my solution helps someone with the same problem. Other CTC televisions can be fixed by the same method.
Jan 07, 2009 | Televison & Video
Deactivate child lock on Onida TV
Try with 1147 (This one worked on my ONIDA TV) OR 5963 OR PRESS ZOOM BUTON AND VOL- KEY BOTH.
Aug 04, 2008 | Televison & Video
HELP to unlocked tv
You will need the original remote control to unlock this set. Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
Mar 07, 2008 | Apex Digital AT2002S 20" TV
Tv is locked the screen is blue with a red padlock in the top corner
my tv is locked & the screen is blue . how do you unlock it ?
Nov 30, 2007 | Televison & Video
Television problem
According to Apex, you can disable the parental lock using the following information.
Oct 28, 2007 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Televison & Video Logo
189 people viewed this question
Top Televison & Video Experts
Electro Med Services...
