Question about HP Compaq nc6220 Notebook
How to remove keyboard
Hp nc6220, need to remove keyboard
Remove (larger) screws from the underside that have a keyboard icon next to them.
Between some of the f-keys are 4 small black strips, these are the restaining clips; gently push them towards the bottom of the keyboard. Once all 4 have been pushed downwars, lift from just above the f-keys and the keyboard will detach.
Be gentle as the connections between the keyboard and the system board will come away fairly easily and are fiddly (if easy) to put back in place.
Posted on Nov 11, 2008
Http://209.85.175.104/search?q=cache:4Af3pZqvSDMJ:www.r3uk.com/index.php/tech-tips/34-disassembly-guides/46-hp-nc6220-lcd-screen-and-surround-replacement+hp+compaq+nc6220+%22remove+keyboard%22&hl=en&ct=clnk&cd=3
Posted on Oct 13, 2008
    Sergeant:
    Champion:
  • 334 Answers
Flip screen all way back pop top panel off then 2 screws for kb under that ribbon to moter bord flip up braket hols ribbon in place then pull ribbion cable out add new one in push bracket back down
Posted on Oct 07, 2008
Disc read error
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 12, 2013 | HP Compaq NC6220 Business Notebook
Where is my ram
usually located in a door on underside of laptop
Mar 28, 2012 | HP Compaq nc6220 Notebook
Where do i find the internal memory card? and how do i get the keyboard off if i need to
first: remove the upper cover of the keyboard by pulling it up with a small flat screw.. then u can see screw which can lead u to the keyboard removal
Mar 25, 2010 | HP Compaq nc6220 Notebook
Pls tell me how to remove the keyboard of compaq nc6220 laptop
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00622160/c00622160.pdf
CHECK THIS ... EXPAND REMOVAL AND REPLACEMENT PROCEDURES AND 6.9 KEYBOARD ... IT WILL GIVE YOU STEP BY STEP PROCEDURE AS IN HOW TO DO THE JOB.. GOOD LUCK
Jan 27, 2010 | HP Compaq nc6220 Notebook
Hello, I cannot find the second memory slot
there is only 1 slot under the bottom cover, the other is under the keyboad
Nov 25, 2009 | HP Compaq nc6220 Notebook
Hello, my hp compaq nc6220 gives insert smart card into reader
Pl switch the machine off and put 2-3 pounds of pressure with your palm on the keyboard closer to the spacebar.. this will fix it..
it is caused by the weakening of the adhesive of the wires below the keyboard.
Long term option - get the keyboard opened by the an professional and cleaned properly..and fixed back neatly...
Apr 20, 2009 | HP Compaq nc6000 Notebook
How do I replace a broken and stuck key.
Most keyboards can be popped out by pulling them straight out and replacing them by pushing them straight in. If you have several sticky keys, you are better off just buying a new keyboard and replace the entire thing. follow the instructions on the owner's manuel how to remove the keyboard on your machine as they are different. it usually requirer removing just a few screws either from under the machine or by removing the small face plate just below the screen..Again, all laptops are a little different.
Let me know if this helps
Apr 10, 2009 | HP Compaq nc6220 Notebook
Keyboard problem
In my HP laptop new one keyboard keys A S D F & J K L& enterkey are not responding but G & H in this line are working properly. how can i solve this problem?
May 04, 2008 | HP Compaq nc6220 Notebook
HP Compaq nc6220 Notebook Logo
1,711 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
