Question about OKI B4400 Digital Mono Printer - Black
New fuser - do I need to reset
I have just replaced the fuser on my OKI B4400. All the lights now flash at startup - is there something I need to do to reset it?
  • 78 Answers
If all the leds are fast blinking, you have a fatal error.
Most likely something has been overlooked during re assembly (forgotten connector maybe ?) as there is no need to reset the fuser.
Posted on Oct 09, 2008
How to reset he 980 fatal error on a oki 610 laser printer
The OKI 980 Fatal error is a Fuser that needs to be replaced. Replace the fuser
that being said you can replace the fuse on the fuser unit or you can do the option below that I DO NOT RECOMMEND
separate the fuser unit in half
Unravel and loosen the wires at the connector at the bottom of the fuser close to the edge so you can pull that connector out a few inches so you can get a couple of wires in there.
Insert a wire into each of the two holes on the back of that connector. 2 and 3 have wires going in, 4 and 5 don't which is the fuse. After you get the wires in the 2 holes. Make sure the wires are long enough to hang out the case. put the case back together and put the fuser in. connect the two wires together and power up the machine. As soon as you here the first motor, which is about 5 seconds into the startup, pull the wires apart. This will make the machine think that the fuser has been broken and reset the fuser life.
You can also purchase new fuse units from ebay etc and replace the fuse unit.
Sep 01, 2014 | OKI Office Equipment & Supplies
B4400 won't pick up paper
Never use spirit to clean rollers. Just fairy liquid and water. All the roller gets is grease from the paper on it. Fairy liquid is the best degreaser. Alcohol will soften the rubber and it will work short term and then the roller is finished and will need replacing.
Feb 15, 2014 | OKI B4400 Laser Printer
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
May 19, 2010 | OKI B6500 Led Printer
OKI B4400 toner - is the chip reusable? I get toner not installed
The chip is not reusable and needs to be replaced every time. You should be able to find a chip on the internet somewhere. I own a Cartridge World printer cartridge refilling store and I do not recommend refilling your own toner cartridges or buying super cheap ones off the internet. The toner is generally such a low grade that it degrades your drum cartridge causing you to replace a $219 drum unit before you should have to.
Jan 27, 2010 | OKI B4400 Digital Mono Printer - Black
this is the OKIB4400 Direct link for the drivers
select ur Operating system if xp vista. or 7
then select language then download it. and install
Dec 26, 2009 | OKI B4400 Laser Printer
This is an "Attention" indicator. Has a lot of meanings when blinking and all of them described in the user's guide. There is also Status Monitor Software that can be installed after the printer driver and which displays printer status on the PC's screen. Much more convenient way to get information from the printer than deciphering indication of the lamp in question.
Jun 05, 2009 | OKI B4400 Laser Printer
Poor copies with OKI B4400
Possibly a fuser issue. Check by sending a 1 pg document to printer and opening cover when paper picked from tray but before it enters fuser. if image good then problem caused by fuser and you will need to replace. If image bad then possible defect with drum.
Oct 04, 2008 | OKI B4400 Laser Printer
OKI B4400 Digital Mono Printer - Black Logo
955 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
