Question about HP Photosmart R817 Digital Camera
HP Photosmart R817
This camera has had problems but I have a new one I got an a code it is on the screen when you turn it on as follows:
Err Line 389 Rev 141
File Fast Application.cpp
Task Root
00910820 00933cc4
0092d5f4 0093a85c
00900530
00900530
00900370
This is all it will show It was ok yesterday. I charged the battery last night and the charger fell with the battery in it but it didn't fall very far.
Something is wrong with the battery or the charging system. I just charged it over night and it works now. The battery still dosn't last very long .
Posted on Oct 08, 2008
Focus motor failure
I had the same issue, just turned cam off and back on, error msg gone. My batt is also not holding charge now using cam w/power connected. Have not used cam for a while, do batts go bad from just sitting?
Feb 05, 2012 | HP Photosmart R607 Digital Camera
Hi, evrytime i send a fax through, i does'nt go through and then i get a error report, 389*. it's a photosmart C309a Hewllet packard. cheer's Rod
rror Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jan 13, 2011 | HP Photosmart Premium C309A All-In-One...
Missing pictures
Lets check the SD card first.
Take out the SD card and put it in external card reader connected to computer.
Copy/transfer all the photos from the SD card to computer.
goto My Computer and right-click the 'Removable Disk' (the SD card drive) and click Properties.
click Tools and click Error checking - Check now button
select the option 'automatically fix file-system errors' and click Start button.
if any errors was found and fixed, you can also Format the SD card. And your SD card should not drop photos again.
Now put SD card back in the camera.
Now take 20 test photos and check if something is missing.
if not take 20 more test photos and check if something is missing.
if all is ok then you can delete all test photos and start taking normal photos.
May 31, 2009 | HP Photosmart R817 Digital Camera
Images are green on camera and on screen session referenca # 922077
i think, .you should change the photo shooting mode.otherwise you reset your whole camera settings.if the problems will continue then you will change your lcd screen.
Jan 13, 2009 | HP Photosmart R817 Digital Camera
Camera self- diagnostic doesn't work
I had this exact problem when I had not used my camera for some time. For me the solution was to take out the flash card, and turn on the camera while pressing the flash button. This allowed me to run the self diagnostic test (which were ok by the way), and then after turning the camera off and on again it worked!
Dec 23, 2008 | HP Photosmart R817 Digital Camera
Zoom is broken
just call bob the builder; because 'yes they can"
Oct 28, 2008 | HP Photosmart R817 Digital Camera
HP Photosmart R817 5.1 Megapixel
Lens does not come ut when we turn camera on?
Jun 30, 2008 | HP Photosmart R817 Digital Camera
All zoom pictures blurry
I am sure your lens is clean but from what you describing you have a definte problem with the lens assy which includes the autofocus sensors. Sometimes is can be a faulty focus motor , dirt between sensor and outer lens. Camera needs to be stripped and checked up.
Mar 27, 2008 | HP Photosmart R817 Digital Camera
Screen not working
It could be that the connection to the screen has loosened up for some reason. If the warranty is void you can try to open it up (if you're up to it), taking the bottoms screws out, and then only the one's close to the screen side on the sides (hehe I hope you understand what I'm trying to tell you ;) )
The screen should be the first thing you see, if you loosen the 4 screws that hold that you can see the connection, just try to fasten it a little bit better, and then screw everything back to it's place.
Let me know if that didn't do the job :)
*I can not be held responisble if you decide to take something apart, It's your hands*
Feb 15, 2008 | HP Photosmart R817 Digital Camera
HP Photosmart R817 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
