Question about Compaq Presario SR1050NX (DW257A) PC Desktop
Distorted voice on computer music
When playing music on my computer from any website or cd, the voices are totally muffled. The instrumental parts of songs play just fine, but as soon as the vocals begin the voices sound totally distorted, I can barely hear them at all actually. I've checked the mixers and things like that, but don't know where else to look. Please help!!!
    Sergeant:
    Champion:
  • 334 Answers
Go compaq .com download latest sound driver for your model under help drivers area k
Posted on Oct 07, 2008
My peavy 118 subs dont play as loud anymore what could be the problem.
Circuit resistance from corrosion, or broken strands int he flex wire connections between voice coil and the terminals. It is also possible the voice coil form is distorted. It is also possible a capacitor in the amplifier is in the early stages of failure.
Jun 11, 2012 | Peavey Pv118 1x18" Subwoofer Speaker...
Distortion troubles with numark ndx400's
The bad news is it could be any of them. or it could be the lighting- CFL's and regular flourescent lighting are bad for audio, as are switching supplies used in TV's, microwave ovens and some musical gear. They are worse than lighting dimmers for noise.
The thing to do is start at the speaker itself and work through the chain of devices to find the one distorting. An old transistor radio is useful here. Most actually do have enough power to faintly drive a large speaker- listen for scraping and rattling- it would mean the voice coil windings may have come loose or the coil form is damaged from heat.
Move back to the amp input and try again- this time listen for a clipped sound if the speaker checked out okay. It would sound like the Charlie Brown adults in the cartoons. That would be a failure of an active component in the amp. If you now hear rattling or scraping- the speaker voice coil is bad and should be repaired or replaced.
If it sounds good, move back to each deck. apply your radio- volume turned down to an input it one is provided. Each should sound clean like the amp did. If no sound or distorted sound is found here- which is the most probable location, it is likely one of the IC chips is at fault. Likely a 4558 if an IC fault, otherwise suspect dirt or hair on the encoder connected to the spin platters.
Mar 30, 2012 | Numark Industries Numark NDX400 Tabletop...
Distorted sound on pc women sound like men voices
Maybe your speakers are bad. How does it sound when you play a music cd or when you watch a music video on Youtube.com?
Mar 28, 2012 | Computers & Internet
Olympus ds 40 can't display recorded voice folders on pc
There are a total of eight folders in the recorder that are in a tree format. Under the “Root” folder
are “Folder A” through “Folder E”, “Audible” and “Music” folders, and recorded or transferred
Language and music data from a computer can be saved as “files”. “Folder A” through “Folder E”
are voice-recording folders, so choose one of these five folders when recording on this recorder.
Up to 200 files can be saved in each folder, and up to two layers can be created within the “Music” folders.
Feb 14, 2010 | Olympus DS-40 Digital Voice Recorder
Casio tonebank ct700 no sound from chords only whilest on fingered chord please advise
More info. If you are chording on the left half of the keyboard, SOMETIMES they allocate or have the option to select a different voice for the part where chords are played. For these, you have to ALSO select a voice for that half of the keyboard. If you don't select a voice, then you would not have anything sounding.
Sep 27, 2009 | Casio Music
Songs Sound Distorted
Setup your device to the default settings, and format it, than copy a new music into the device and listen.
Hope this helps.
Jun 24, 2009 | SanDisk Sansa m240 MP3 Player
No audible voices
The problem sounds like a setting miss match , with music it is not so noticeable as it is louder and has higher spectrum of sounds , but with monoliphic voices you pick out the disinction more check your sound utilities program particuarly the graphic equalizer if it has one windows does in sound properties and advanced setings if you have a seprate sound utility ie: hd sound etc check that your effects settings havent been changed ...Regards Vortash
Jan 27, 2009 | Pioneer CDJ-800 Turntable
Music from my nono just fine but no or distorted voice
Have you tried any other headphones? Check the jack for corrosion possibly..
Dec 17, 2008 | Apple iPod nano
Recording my voice through computer with keyboard
You need a Sampler. Either software or Hardware will work. A sampler is the device that will make it possible to play your voice on your keyboard. There are many software samplers available, take a look at websites like sweetwater.com or musiciansfriend.com and have a look at the pc software section. You will also need a MIDI connection for your computer to enable the keyboard to talk to your computer (runs around 50 bucks). I would look at a program like Sampletank or others.
Dec 05, 2008 | Music
No voice sound through speaker with DVD system, only music?
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
Mar 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Compaq Presario SR1050NX (DW257A) PC Desktop Logo
230 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
