Question about Gateway FPD1975W 19" LCD Monitor
Monitor appearance is short and fat
My monitor appearance has everything shorter vertically and wider horizontally. I have tried to adjust the resolution and nothing seems to affect the above appearance problems
  • 68 Answers
Set the resolution to its native resolution 1440 x 900 this should correct things.
Posted on Oct 07, 2008
One inch of the window is off the screen
you could adjust the vertical and horizontal adjustment through the main menu of the monitor. buttons on front of monitor. auto adjust may fix it but if it does not look for the vertical or horizontal adjustment fot the area effected. if this helps please rate with comment
Feb 03, 2013 | LG Computers & Internet
Vertical n horizontal ic
Are you asking about this LCD Daewoo (F227B) monitor? LCD monitors do not use Vertical/Horizontal IC like the CRT type for the H/V Yoke.
What is the problem with the monitor?
Common problem with LCD monitor:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | Daewoo F227B Monitor
How do I adjust the 22 in. rectangular screen to prevent images from appearing wider than normal. For example, pictures of persons make them look fat and wide.
You can use any other image viewing software such as Picasa. It will open images at 100% size but you can change the size of images
Jan 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Horizontal line appears on my PC Acer screen and
There are two possibilities: That the monitor is bad, or that the video board is bad.
The easiest way to test is to install a different monitor and see if it does the same.
If it does the same, then it is the video board. If not, it is the monitor.
Sep 17, 2009 | Emprex LM2201 22" LCD Monitor
Monitor Curcuit Problem
re-adjust the vertical and horizontal size then exit the menu
Oct 22, 2008 | AOC LM729 17" LCD Monitor
Monitor resolution
Sounds like either the trapazoidal is off or the pincushion is set improperly. You should be able to find those settings via the monitors onboard menu. Either one can create such a problem.
You might also check into finding the factory defaults selection. This will reset all of the resolutions and refresh rate settings.
When you adjust your screen follow these steps in order...
Pincushion : Makes the screen look like ( ) or ) (
Trapazoidal : Makes the screen look like / \ or \ /
Horizontal : Basically stretches the screen wider or skinnier to fit the monitor
Vertical : Basically the same as Horizontal, only with the up and down properties
Contrast / Brightness : Use this to find the perfect white and blacks
Color : Finish your setup with adjusting to the perfect color.
This way you can always have your monitor set like you want it.
Sep 12, 2008 | Gateway FPD2275W LCD Monitor
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor "offset"
try adjusting your refresh rate
Dec 13, 2007 | Acer AL1912 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
98 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
