Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner gives message " cannot connect to computer " but everything is connected
Try disconnecting the printer, uninstalling the software via Add/Remove Programs[remove all HP OJ 6110 and old HP driver installs], Shutdown and restart, leave printer disconnected, then try installing the software again but wait for the installation software when to tell you to connect the printer.
Try this link if you do not have the software handy,
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=oj+6110&submit.x=0&submit.y=0
Check the label on the back/bottom of the printer for the exact sub-model to match with correct driver.
Posted on Oct 07, 2008
I can print but cannot scan
Uninstall all of the printer software and reinstall it.
May 29, 2017 | Canon Pixma MX320 All-in-One Inkjet...
It gives me this message: Scanner not connected I install, the neat scanner, check everything is connected correctly but nothing. Please help me. thanks
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps
Jun 03, 2011 | Computers & Internet
When I try to scan I get a message - connect to Twain source but I don't know what they are talking about?
The TWAIN device is the scanner itself. The program seems to be saying it can't see the scanner.
Is this scanner new to your computer?
Have you installed the driver for it?
Which program is giving you the error message?
Apr 12, 2010 | Canon CanoScan 5000F Flatbed Scanner
Getting an Error Message when trying to scan
SCSI devices are detected as the computer is booting. If your scanner was powered on after your computer was already up and running, it may not have been identified by the SCSI card. Try leavinging the scanner connected and powered on and then reboot your computer. Also, the pins on the SCSI cable connectors are easy to bend; inspect the rows of small pins with a flashlight or just try a different cable if you have one.
Dec 01, 2008 | Office Equipment & Supplies
Error message: enable to connect with scanner
Part of the problem may be that Visioneer did not develop any drivers for Vista considering that the 5800 had reached E-O-L.
Sep 25, 2008 | Visioneer OneTouch 5800 Flatbed Scanner
Nikon Coolscan 9000 not recognized by XP computer anymore....
I read and would like to thank, the person who mentioned this as a solution. It was stated that if you have more than one firewire on your computer, when you open the Nikon, both signals, or whatever happens in computerland, don't connect. Upon removing the drive in the other firewire, Nikon clicks in everytime. Answer: have only ONE active firewire at a time. You may need to unplug the cable to the scanner and reconnect. But that's it. I've not had any problems since
Jun 09, 2008 | Nikon CoolScan 9000 ED Film Scanner
I can't get the scanner to work on my mp160. The printer and copier work fine.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-13
Feb 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
"Camera not connected." -- Serial connection
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 820 Digital...
"Connection failed." -- Serial connection
The "Connection failed" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
