Question about Sewing Machines
How do i thread the bobbin
I need to know how to thread the bobbin on a Brother XL 3010 sewing machine. Like if the bobbin runs out of thread i need to know how to thread the whole thing.
I have a new sewwing machine Eurp-pro Shark automatic but I don't know to thread the bobbin
Posted on Oct 11, 2008
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
I have a brother model XL-5500 sewing machine but I do not know how to wind elastic thread onto the bobbin please help me
Generally, elastic thread should be hand-wound onto a bobbin to use in a sewing machine. This allows the elastic thread to be wound without any stretch incorporated before stitching.
Feb 22, 2016 | Brother Sewing Machines
How do I fix the stitching on my Brother XL-3010?
Your tension sounds far too loose. Or your needle is blunt.
Jun 25, 2015 | Brother Sewing Machines
I've a Brother XL 3500 sewing machine and when I
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Apr 11, 2013 | Sewing Machines
How to put the bobbin case back together on a brother xl 2600 i
I would go to a sewing machine store with it and ask them it it looks right .if I wasn't sure
Oct 10, 2012 | Brother XL-2600I
How do i set the tension on my brother xl-3010 sewing machine . the bottom thread is always in knots but the top stitch is perfect. i do not know which wheel to turn for the bottom tension.
I don't have this machine, but the tension on the bobbin is usually set by the tiny screw on the bobbin case. insert the bobbin into the case so that the thread unrolls counter clockwise. Make sure that there is no lint in the bobbin area.
May 31, 2010 | Brother XL-3500
Brother XL-5130 Sewing Machine
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Feed the thread thru one of the holes (the hole that will be on top) going from the middle of the bobbin thru to top. pull up about 2 inches, push the bobbin over to start winding and before pressing the foot, hold the 2inch piece sticking up. HOLD TIGHT. after the thread is wound about 25 times, stop winding and snip the 2inch piece level with the top of the bobbin. Finish winding.
Apr 13, 2009 | Brother XL-5130 Mechanical Sewing Machine
How do you thread the bobbin
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000062/xl513052325340ug01enesfr.pdf
this is the manual for your machine, in PDF click "index" then bobbin and it shows you how to to thread the bobbin. Good luck!
Mar 26, 2009 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
327 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
