Question about Technics SCEH790 CD Shelf System
Technics compact disc player broken
MY CD PLAYER WILL NOT ACCEPT ANY CD's AND COMES UP ON AMPLFIER AS ERROR AND DC TRAY COMES OUT BUT DOES'NT RETURN ON IT'S OWN
  • Anonymous Feb 04, 2009
    my problem is on the cc/dvd player on the sldv250 model it wont play cd/dvd just shows no disc , any help please , john19norwich@hotmail.co.uk
How do i connect all of the seperates together
Posted on Apr 01, 2009
    Sergeant:
    Champion:
  • 334 Answers
Is it all cd or just new burned ones try older orginal cd once still does it bad tray man on this dought technic sells ust tray player on this model
Posted on Oct 07, 2008
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Changer states checking disk, error
Possible broken drive belt, that's what caused the same error on my unit. Very easy to replace, just take off the top cover and the motor and belt are readily accessible.
Feb 03, 2014 | Technics SL-MC700 110-Disc CD Changer
When i insert a CD, it won't accept it, "disc error" appears. What is the solutions.
hello there soenensistva
Well first of all Compact discs are easy to be read by a DVD player then ordinary Cd player cause of their lens are made for more compressed Data discs..there for try some of the options
1. make sure that the disc Surface is Clean and don't have finger prints or any other material that is disturbing the the read process between the CD and lens present inside CD player
2.if your CD is precious for you ( that consist some important Data you may need ) then try a DVD player for that
3.if both things doesn't work try a cleaning Cd for Cleaning the Head of CD player .
i wish that your problem may be solved
Best Regards
Oct 15, 2012 | NAD T550 DVD Player
Disc stuck in cd player
Easy, turn off the power, remove the lid by unsrewing all the screws on the side, back and top of the lid. When removed you should see the CD jammed somewhere at the rear of the disk carrier. be very carefull and slowly remove it. The disk may be already scratched but if you're carefull you can stop further damage. Also don't force any part of the tray they are only plastic. If you can't get the disk out things start to get awkward. Write backmor take the unit with the lid off to a repair shop it shouldn't take them long to get it out.
Apr 07, 2010 | Technics SL-PD887 5-Disc CD Changer
CD tray on Technics SL-PS670A compact disc player will not close
Just a quick notion! Had you made sure the transit locking pieces were removed?
Jan 10, 2010 | Technics SL-MC6 CD Player
Inserted cd disc. play music on cd but will not eject the disc cd is stuck in cd player
Mostly The cd is jammed between the laser sensor and the cd rotator.Try removing the audio player and reseting the whole device if possible.Or if you have sufficient technical know how.Open the player try to manually open the disc tray.and remove thedisc.This can happen even  if the disc is broken inside the player.
Sep 28, 2009 | 2004 Jeep Grand Cherokee
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Oct 06, 2006 | Technics SL-MC6 CD Player
Technics SCEH790 CD Shelf System Logo
214 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
