Question about Magic Chef MCWC30MCG Compact Wine Cooler
MCWC30MCG stopped cooling
The unit just stopped cooling one day.  An intermittent clicking sound started and the compressor was really hot. It's about 3 years old.  I got a phone quote of $350-400 if the compressor has to be replaced!!  Could it be something simpler that I could replace myself?
  • Handy Hubby Oct 08, 2008
    I suspected as much but was hoping for better.
  • 750 Answers
Handy hubby,
welcome to Fixya,
It sounds like the compressor!
Not worth replacing this very expensive part.
Was it so hot you could not keep your hand on the compressor?
If yes then it's most likely your compressor.
Happy to be of assistance.
Sorry about your lose
Huuum
Please remember to leave a rating
Posted on Oct 08, 2008
  • Neil Golan
    Neil Golan Oct 08, 2008
    Dear Handy Hubby,
    I GOT IT!!!!!!!!!!!!!!!!!!!!!
    Magic Chef is now owned by Whirlpool.
    Here is the Consumer Affairs Tel #. 800 253-1301
    They handle all customer problems above and beyond Customer Service, and are authorized to do what it takes to retain all customers.
    It's easier to keep the customers you have than to find new ones!
    Prior to 2006 all major components including compressors had a 5 year warranty!!!!!!!!!!!!!!!!!!!!!!!
    So if it's been 3 years since you bought it, you should be covered
    I think they will take care of you!
    Bless You,
    Huuum
    Please remember to leave a rating.
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
Oct 15, 2017 | GE Refrigerators
Unit is running and not cooling
If the compressor is quite hot to the touch, that usually means that there is a problem with the compressor. Could be a short or open winding, but either way you will need a new compressor.
Apr 09, 2014 | Magic Chef MCWC30MCG Compact Wine Cooler
Not cooling and compressor is hot
If the overload was open circuit you would not have a hot compressor. The overload activates because the compressor won't start. If there is a capacitor starter, change it. If not let it cool for at least a day then try again. If still no go, replace compressor.
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
Compressor seems really hot. Had clicking sounds in my unit, but it was still cooling. Last week it stopped. I replaced the motherboard and it worked great for 2 days. Now it stopped cooling well. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It sounds like you have a small leak in the refrigeration system and that your unit is low on freon...
.there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 12, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
2000 Mitsubishi Spyder ac replay intermittent trouble
two things you may try, relocate ambient sensor to colder place, remove it from front bumper, and connect the two wires on refregerant temp sensor located @ rear of compressor, be carefull and observe your a/c system after doing this
Jun 21, 2010 | 2001 Mitsubishi Eclipse Spyder
Wine fridge not cooling
It is normal for a compressor to be hot to the touch, but not super hot. clicking noise sounds like the relay located on the compressor terminals is bad. Hope this helps
Jul 27, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef MCWC8DSCT Wine Cooler
I had the same problem. I fixed the problem by replacing the main cooling fan that is mounted over the electrothermal cooling unit.. Fan can be ordered from RepairClinic.com.
Sep 16, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef MCWC30MCG not getting cold?
You need to replace the Ptc unit attached to the compressor. Go to REPAIR CLINIC.COM and order the following part. 1206838 Ptc relay. They also will show you were it is located and how to replace it. Compressor tanks very rarely go bad. It is an $11.00 dollar part
May 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef MCWC30MCG Compact Wine Cooler Logo
550 people viewed this question
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
