Question about Panasonic Office Equipment & Supplies
I can send but not receive a fax on my KX-KP80 machine.
    Genius:
  • 2,120 Answers
Do you have paper and toner?
Is the phone line attached to the LINE port of the fax machine?
Posted on Oct 07, 2008
Receiving faxes
Certainly not your fax machine problem.
The client needs to verify your fax number.
Oct 03, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
CAN'T SEND OR RECEIVE ANY FAXES
HI.when u try to receive or send any fax.fax gives any msg r not.first check ur telephone line.u have to connect it in line.there are two places in fax .one is ext and second is line.check it u r putting it line.for receiving check auto answer .put it on fax only mode.u will receive fax.MIAN AKHLAQ.if it helps rate the solution.
May 16, 2009 | Panasonic KX-FPG381 Plain Paper Thermal...
Want to connect fax machine to pc
The KX-FM131BX, KX-FM131CX and KX-FM131AL do not connect directly to a computer. They only have RJ-11 connections (to the phone line (line in) for all models and to another phone or answering machine (in some cases).
To send and receive faxes with a computer, you need some sort of USB or network port on the machine. Brother has some that may fit your needs: http://www.brother-usa.com/Fax/ModelDetail/2/FAX2840/Overview is one of their lower end models.
I hope this helps.
Dec 06, 2017 | Panasonic KX-FM131 Fax
''Document Jammed'' error message
Open the document feeder and look for a switch actuator stuck in the down position.
Nov 19, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
We can send fax but can't receive...new fax line, old fax machine...panasonic kx-fc195
hi zebaron,
check your ink film maybe its empty, check the receiving mode if its on automatic mode, if its on manual mode you have to press the start button to start receiving fax.
hope this help....
Jul 24, 2008 | Panasonic Office Equipment & Supplies
Panasonic kx-fpg376
more then likely the sending fax had a problem and did not send you the complete fax. You should have them resend the page you're missing.
Hope that helps...
Jun 19, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Faxing problems
if you put the document in right direction(face up or face down)-your scanner unit may be out of order or unpluged firmly into the main board socket check it and reinsert scanner unit plug again.
Jan 10, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Panasonic fax kx fp342 regarding
my fax do not send paper but it's reciver and copy it .
what solution ?
Dec 29, 2007 | Office Equipment & Supplies
47 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
