Question about Magic (I5252DE) Burner
No words come on to choose from for the burning task
It comes on and makes noise & the doors to the 2 trays open & by accident it might copy but there's no menu to choose from. it is an optical magic corp cd duplicator. i haven't used it for a while and am just getting around to copying more cd's & can't get it to work like it did. It is an external. Please help
    Sergeant:
    Champion:
  • 334 Answers
Xcheak online latest firmware for it and software 1st ok
Posted on Oct 07, 2008
Word docs open with a blank page.
Do your doc open correctly if you open Word first (open Word first, select FILE - OPEN and then the file, the DOC file opens)?
You can also open your word doc with IE or Firefox:
Launch IE, then at the File Menu, choose "Open" and browse to the Word File. You can also try Firefox the same way (or right click the doc and choose open with and find IE)
make sure your text wasn't accidently changed to white-then it would look like a blank page, see if you can highlight the text.
The files may have been saved as Macro enabled docs. Right click on one of the documents, click Save As. Choose Save As a normal doc. The next time you open it, it should open correctly.
This is a tough one
Mar 31, 2013 | Microsoft Word Computers & Internet
There seems to be a grinding noice coming from the bottom of the copier. It will feed paper from either source, the tray or the manual feed, and then the copy gets caught and shuts down the copier and you...
Diagnosing noises over the internet is an impossible task unless it is a known problem on a particular model. usually grind noises are casued by something trying to turn something that wont. It maybe something as simple as a siezed drum. As you have not stated what model of copier you have, i am sorry but i cannot proceed any further.
Jul 24, 2011 | Canon Office Equipment & Supplies
Error c-0910
C-0910
The Lift-up Sensor is not blocked even after the lapse
of a given period of time after the lifting motion has
been started.
Basically your paper tray 2 did not lift right. Open the tray and make sure the paper is loaded correctly. The paper should be touched on all four sides by the tray or by adjustable guides. Open and close the front door with the tray out. Once the machine is ready to copy close the drawer you should hear a slight buzzing sound as the tray rises. If you don't or you hear a banging or grinding sound the tray lift motor may be damaged and you will need to call a service technician.
If the code keeps coming back pull out tray 2, open and close the front door to reset and leave the tray 2 partially pulled out until a technician can repair.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How to clear Malfunction code C-0204
C-0204 The Lift-up Sensor is not blocked even after the
lapse of a given period of time after the lifting
motion has been started.
Apr 08, 2010 | Konica Minolta bizhub C351 All-In-One...
Can't print new documents but keeps printing old documents
you acumulate a number of errors or print exe commands into the printer folder and it takes them first ... do not print anything ..but open the printer folder and /delete all errors and elder comands..
also is possible that into a previous print you set the wizard to print a number of multiple copies and do not have enough paper or so ...or just closed it before completing ..this will also make it print the elder command first ...so ...open the folder...( it can be opened from the tray system by right click and choose (tray =bottom right on task bar )...
Nov 07, 2009 | Canon PIXMA MP510 All-In-One InkJet...
I have problem of code c-910 how can i solove it
You did not provide the make or model number but based on the code I will suggest a solution for a Konica/Minolta and a CO910 code. This error code means your 2nd paper tray id not lifting properly. I woul;d suggest opening tray 2 and removing, then reloading the paper in that tray. If this does not work you can verify this is the problem by leaving tray 2 open and then opening and closing the front door to reset the code. If the machine comes to ready and can make copies with tray 2 open the you will know there is an issue with tray2. You can leave the tray open to allow you to make copies until repairs can be made.
Good Luck.
Nov 02, 2009 | Office Equipment & Supplies
Karaoke Machine - words are overlapping/jumping
The Sining Machine #SMG-301 has a problem with not playing because of the word 'DOOR' coming up on the readout. I've checked the door/Tray to make sure that it was closed and when you open up the tray/door to put or take out another disk the word that comes up on the readout is not DOOR it's OPEAN! Any suggestions?
Aug 24, 2009 | B&W 5.5" TV/CD+G Monitor Karaoke Machine...
I don't know how to copy two pages (size A4) at
open the photo copier put the original copy on top of the screen words facing down then cover the machine then press copy then ok after it will copy, after remove the copy from the photocopier then pull the tray and put that copy on that tray the words copied facing up then put the tray back then open the upper side where you put the original copy then change it to another side, cover the photocopier, press copy then ok it will copy on boss sides.
Jun 10, 2009 | Canon iR 1600 Laser Photo Printer
Xerox 8560MFP won't print first page from one tray and rest from another
Microsoft word overides the print driver for page choice. Choose from within word File | Page Setup | Paper.
Tray one on this printer is the manual feed tray. tray 2 is the first drawer.
Ensure the printer driver is set up for the additional trays
Jul 02, 2008 | Xerox Phaser 8560MFP Laser Printer
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Magic (I5252DE) Burner Logo
Top Magic Computers & Internet Experts
Computer Links
Lee Durbin
Lee Durbin
Are you a Magic Computer and Internet Expert? Answer questions, earn points and help others
