Question about Electrolux Washing Machines
I need disassembly instructions for a Kenmore Automatic Washer model number 110.24942300. I am trying to help a neighbor correct an internal water leak and I don't want to destroy any fasteners if possible. Thanks Mac
  • 943 Answers
HI. thanks for the question. the cabinet comes off. to remove. 2 screws on each corner, of the console. remove. lift console. 2 brass clips . remove them. disconnect lid switch harness. remove the cabinet. look for the leak. thanks the appliance doc. please rate my answer.
Posted on Oct 07, 2008
Front load kenmore elite washer show code FE why
The FE code is probably an overflow error. The intake valve is stuck in the open position and the washer can't advance to the next part of the cycle with the water coming in. You need to replace the inlet valve.
Since you didn't provide the full model number, I can't point to the correct replacement part for you. Please post a comment with the washer model for additional information. If your washer is still under warranty, contact Sears for service. ( searspartsdirect.com will likely have the parts diagram and sell the correct part. However, other vendors may have the valve at a better price. This will depend on the model.)
I hope this helps.
Apr 03, 2015 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I need a washing machine manual for a Kenmore top loader, model number 22422100
Please check your model number. Kenmore washers have a 3 digit prefix followed by another 8 digits. If your full model number is 110.22422100, then Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/12008/KENMORE-Residential-Washers-L0407343?brand_name_search=110.22422100 . This is a generic manual for all Kenmore one-speed automatic washers. A copy of the descriptions of the washer settings is available here: http://www.managemylife.com/mmh/owner_manuals/15224/KENMORE-Residential-Washers-L0305156?brand_name_search=110.22422100 .
I hope this helps. If your washer has a different prefix, please add a comment with the prefix. I'll try to find manual for the correct model.
Jan 22, 2012 | Kenmore Washing Machines
My Kenmore 800 series washer is leaking water all over the floor and i can't find where its coming from. It only leaks when its on and running. I tried to take the back of it off to see where it was coming...
Some of theses models have a tendency of leaking out the side of the pump housing. In this case you will need to replace it. Here is a link to help disassemble and acess the pump.
Disassembling a whirlpool style washer
Oct 13, 2010 | Kenmore 22422 Top Load Washer
I have a top load kenmore washer the spin cycle works but it wont fill up with water.
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. Here is a video at that will walk you thru the testing a water inlet valve. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Oct 06, 2010 | Kenmore Washing Machines
Washer fills very slowly
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topwaterinletvideo.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Jul 21, 2010 | Kenmore 24032\24036 Top Load Washer
How to disasemble model 11020722
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers. Actual Model Numbers are necessary to correctly diagnose the problem.
Can you describe exactly what you want to disasemble??
Jan 25, 2010 | Kenmore Washing Machines
Kenmore washer 25842 leaks
Repairclinic.com has a repair manual available for Kenmore direct-drive washers for about $20. The item number is 1170635.
The back panel is not designed to come off on this model washer. The operator console comes off, but the panel along the back of the washer does not. You need to remove the exterior washer case to access the internal components.
If you have a leak, the most common cause is a worn drain pump, or leaking drain hoses, but you need to disassemble the washer to be sure. DO NOT lay the washer on its back. The gearcase contains oil and it may leak through the breather hole.
The following link explains how to inspect your washer for leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
Read through the instructions provided and let me know if you need further assistance. I hope this help you.
Jan 10, 2010 | Washing Machines
My kenmore elite calypso washer
"Ld" indicates Long Drain: Ld flashes when the water level does not change after the drain pump is on.
depends on the following factors:
1-> the drain pipe could be longer than 8 feet
2-> the drain hose could clogged or kinked
3-> the pressure hose connection from the tub to the machine motor control could be pinched or plugged?
4-> and finally the pump might not be running well.
If you need any sort of help with the disassembling of machine tell me the exact model number and i can provide with some internal diagrams.Good luck with the machine.Please do rate my solution, also do post comments in case of further doubts.
Jan 24, 2009 | Kenmore 20172 Top Load Washer
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore HE2 Washing Machine Leaking
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
May 04, 2008 | Washing Machines
Washing Machines Logo
106 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
