Question about Compaq Presario 5000 PC Desktop
Computer problems i having problem downloading on my computer it say publisher is unknown and that there is a certificate error
  • 749 Answers
Any driver Microsoft has not tested and signed off will cause windows' to display this warning. Windows tries to protect itself from malicious software. If you know this software is safe, hit the continue anyway button. always be prepared to uninstall or disable this if it locks up your computer.
Posted on Oct 07, 2008
Unknown certificate error
When you try to install software or game than some time it say certificate error, Frist change your date to 2002 and try to install software
Sep 11, 2012 | Coby kyros Tablets & eReaders
On itunes i am trying to buy songs but error 9808 came up what do I do????
The 9808 error is usually caused by a problem connecting to the iTunes store server. It can be something like the date and time on your computer being wrong and so confusing itunes or it can be a problem with your security software. It is often advised to Uncheck the box labeled "Check for server revocation certificate" in the security section under the advanced tab of your Internet Options settings.
1) Go into your Internet Options
2) Click the Advanced tab
3) Scroll down to Security
4) Uncheck the box labeled "Check for server revocation certificate"
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 27, 2010 | Apple iTunes
I am having problems connecting VPN Connection on my Windows 7, it says there need to be a machine certificate installed before i can connect using L2TP/IPsec. error code :766
"Error 766: A certificate could not be found. Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate."
"Error 766: The L2TP connection attempt failed because the security layer could not authenticate the remote computer."
Cause: Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate. You will see this error message when such a certificate is not available.
Typically, this error is generated on a remote access server that has active L2TP ports configured, the remote access service started but there is no certificate in the computer certificate store. This generates an event log message that tells the administrator that L2TP ports will not be able to accept calls until a certificate is acquired and RRAS is restarted.
Resolutions: 1. If you use PPTP VPN, select Automatic in Type of VPN.
2. If you use L2TP, check the remote access server and make sure there is certificate in the computer certificate store.
Sep 18, 2010 | Computers & Internet
After recovering to a recovery point my itunes gives me the -1202 error no matter what I try to opne. I have it installed ok on my XP computer, but am trying to move it to my laptop.
Upadte your root certificates from here:
http://www.microsoft.com/downloads/details.aspx?FamilyID=f814ec0e-ee7e-435e-99f8-20b44d4531b0&displaylang=en
download and install, that should solve the issue.
Aug 15, 2010 | Apple iTunes
I have an error with my itunes. -1202. How do I fix this?
ok - so the fix is very long and time consuming but I listed it if you want a work around go to the bottom of this page !
make sure your date and time and time zone are correct on your cpu2_bing.gif
if this dose not fix it try this
1. If you look a the Certificates snapin for your 'Local Computer' inMMC and only find a few Trusted Root Certificates then you should runthe Microsoft2_bing.gif May 2009 Trusted root certificate update from here: http://www.microsoft.com/downloads/details.aspx?FamilyID=f814ec0e-ee7e-435e-99f8-20b44d4531b0&displaylang=en
The above fixed the 8192 problem for at least one person that I know of.
As a matter of fact it wouldn't hurt to re-run that whether you think you're missing Ceritificates or not.
2. If you ever had your computer connected to an Active Directory2_bing.gifdomain then there might be a problem with your Certificate policy. TheLocal Computer Policy MMC snap-in might show you some settings that youcan fiddle with.
This fixed a raft of problems for people to do with updates and sign-ins an so on.
3. Apple now have a support document that points to to an MSknowledgebase article on how to troubleshoot certificate problems onVista2_bing.gif. It's long and involved and the final step if nothing has workedis a reinstall. You should check out the article here: http://support.microsoft.com/kb/822798
This last one was presented as a solution to problems that were fixed by the first two so try those first.
WORK-AROUND
Right click on"redeem" on the itunes home page. It will give you a choice to open orcopy - choose "copy this link". Then paste it into a new internetexplorer window. Accept the security prompt then it should load up thespace to put your code in."
Apr 08, 2010 | Apple iTunes
Error 1202
1. If you look a the Certificates snapin for your 'Local Computer' in MMC and only find a few Trusted Root Certificates then you should run the Microsoft May 2009 Trusted root certificate update from here: http://www.microsoft.com/downloads/details.aspx?FamilyID=f814ec0e-ee7e-435e-99f8-20b44d4531b0&displaylang=en
2. If you ever had your computer connected to an Active Directory domain then there might be a problem with your Certificate policy. The Local Computer Policy MMC snap-in might show you some settings that you can fiddle with.
3. Apple now have a support document that points to to an MS knowledgebase article on how to troubleshoot certificate problems on Vista. It's long and involved and the final step if nothing has worked is a reinstall. You should check out the article here: http://support.microsoft.com/kb/822798
Best of luck!
Mar 21, 2010 | Apple iTunes
Trying to redeem itunes gift cards and I keep getting an error of 1202...please help
Mar 14, 2010 | Apple iTunes
When try to install theme, error coming 'Expired Certificate'
plz tell me the format of theme u use, maybe its damaged,
try true ones
eg. here is a theme link for ur phone(download it):
http://abul.mobile9.com:8080/download/content_delivery.php?key=NDI1L245Nl91bzk2bDNtNS5zaXN8MTI0MDIxOTQzOXw=
Apr 20, 2009 | Nokia E66 Smartphone
Gmail, Blogspot & Googletalk
hello, this is the problem with the SSL security certificate.. to solve this problem in firefox ... first when this error is displayed there wil be a link that says " add this certificate " , click that link and add the certificate to ur browser.. the problem will be solved ... or else go to internet options in ur browser and check for certificate settings .then download the certificate from google with the option given there....
Feb 03, 2009 | Google Talk
Certificate errors
This is simply letting you know that comcast.net has not updated or chosen to participate in a certificate program that microsoft uses.  It is nothing to worry about with your email site.  If you go to unknown websites I recommend that you do not continue if you get this warning.  Only way to get rid of it is to reduce your protection on the internet which I would not recommend.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
