Question about Acer TravelMate 2300 Notebook
I am trying to connect my laptop via a svga vga cab to my t.v
  • tgrdjones2 Jan 29, 2009
    I am trying to figure out how to hook my laptop to my tv
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
I have an aspire one laptop and a video convertor.
Are you connecting the svga out of the laptop to hdmi of tv via a converter? This set should have an svga input on it. try connecting this directly to svga on computer. Computers and converters and hdmi inputs on tvs are always a challenge. Newer laptops have hdmi outputs on them and are seem to work better.
Jan 05, 2014 | Panasonic TH-50PX50U 50 in. Plasma HDTV
How to connect my pc to my tv & use it as a monitorbaxterstead000@hotmail.com
-get a vga cable(usually both ends are male) - connect it to the vga port on the laptop then the other end to your tv -press fn+f2 to switch the display to your tv( this is model/brand dependent, check your user's manual for more info)
Oct 23, 2010 | Computers & Internet
Can I change the Presario 1200-XL103 Laptop video mode from VGA
U just went to ur brand site.. and there u enquire about ur problem.
Sep 29, 2009 | Computers & Internet
Can I go from VGA to SVGA?
If the question is can I convert my composite video output to a super video input then the answer is NO,
The composite is coaxial (2 wires) the S-Video uses 4pins and there is no S-Video output on a Presario 1200 laptop.
You can however use a Multi-AV SCART adaptors with Input/Output signal switch where you plug in the composite video output into the top video and 3.5 mm jack stereo audio into the mono audio connections on top.( via a stereo to mono cable)
http://upload.wikimedia.org/wikipedia/en/thumb/a/a7/Multiconnector-scart-chti.jpg/200px-Multiconnector-scart-chti.jpg
Hope this is the answer you are looking for !
Sep 27, 2009 | Compaq Presario 1200XL103 (155726-163) PC...
Connecting TV via LAN to a laptop as a monitor
You can connect any laptop to any TV with an SVGA port by use of a pair of Baluns. These run about $49 each; you need two. Try MCM.com. They have several models. As long as your LCD has an SVGA or VGA monitor  input the baluns will emable you to send a signal from laptop to display.
May 07, 2009 | Sony LF-X1 12.1 in. LCD Television
How to watch laptop in my Sony Bravia?
you need to clone the acer screen using ati utility
Jan 26, 2009 | Televison & Video
My Dell D610 laptop monitor has went completely white.
I don't have a Dell D610 with me, there should be a VGA/SVGA port on the back. If not, there's a DVI port.
If the video has not gone bad, you should be able to. Connect the monitor to the back vga/svga port or DVI port.
The are several controls to activate the monitor for Dell computers.
CTRL ALT <
CTRL ALT F10
FN F8 (CRT/LCD)
FN D
FN F12
Good Luck.
Dec 30, 2008 | Dell Latitude D600 Notebook
Laptop to TV
I dont believe that you can hook that model up to a TV you have to have a certin video output and it also would depend on your tv as well. But i am about 100% sure that series does not have the output you need you usally can connect via S-cable
Dec 04, 2008 | Dell Inspiron 2200 PC Notebook
Connecting a sony Vaio vgn-fe570g laptop to a Samsung Monitor
There is an issue with the vga port on 2006 - 2007 sony vaio laptops. It doesn't push enough power to samsung lcds. There are all sorts of complicated solutions suggested by all sorts of people. Don't waste your time. Get yourself a connection cable with gold contacts and you'll be straight. It costs approx. $33.99. I got this one and it works fine (and I have a weak-*** TZ):
http://www.circuitcity.com/ssm/Nexxtech-VGA-SVGA-Monitor-Cable-6-N6VGASVGA/sem/rpsm/oid/192558/catOid/0/rpem/ccd/productDetail.do
May 22, 2008 | Sony VAIO VGN-FE870E/H Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
