Question about Digi Computers & Internet
Digi box When you plug the phoneline in the digi box it cuts the phone off the telecom enginer said i have had a lightening strike
    Scholar:
  • 87 Answers
Why would you doubt that it is fried? It kills the line when you plug it in, so would shorting the wires together. Get a new one. It's toast!
Posted on Oct 31, 2008
Sab digi box wont boot up
Hi Pat,
If your DIGI box has a card, please pull out the power plug and then take out the card, clean it and insert it back. Power on the box. If it works, very good. Otherwise call the service provider.
May 31, 2015 | Televison & Video
How can I set up a Bush Digi Box with 2 scart sockets to a Sony combined DVD & Videao Recorder with 2 scarts to a Sony TV with 3 scarts
Bush Digi box - 'TV' SCART to TV
Bush Digi box - 'VCR' SCART to DVD/Video recorder 'TV' SCART
The digibox will pass through when the DVD/VCR is playing.
Aug 30, 2014 | Televison & Video
Configuration settings PIN code
Try Hard Reset your Phone
or
Here's a hints on how to repair or fix Nokia 5800 XpressMusic Digi Mic Knopfler problem issues.
A guide picture below which I included an schematic diagram shows each every components and line paths for quick test and check up procedures.
Digi Mic Knopfler Pin configuration:
1. L/R - microphone's left and right audio signals groundings
2. CLK - Audio Clock data
3. Data - Digital Microphone data
4. VDD - Power supply voltage
http://2.bp.blogspot.com/_8JZhVVmpICU/TBnMEY2FYyI/AAAAAAAAAiI/KWb0ERKLIPE/s400/digi+mic+knopfler+schematic.jpg
Locate and trace each and every components, line paths and corresponding connection as shown on a picture. The red highlighted components and line paths is for the power supply voltage which came from Power management IC (AVILMAS) Vsim2- approximately 2-3 volts.
Test and check this components and track the supply voltage from C220 to C2170 then through the digi mic knopfler pin 4.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnNuXjiK5I/AAAAAAAAAiM/zRyjq5oSGEA/s400/nokia+5800+xpressmusic+digi+mic+knopfler.jpg
The pink highlighted components and line paths is for Audio Clock data signal, which is came from the Audio Codec IC (Avilmas) then flow across R2201 and R2170 (valued 100ohms each) then to the Digi mic knopfler pin number 2. Check also the C2173 valued 22p Clock filter capacitor for possible damaged.
I included step by step procedures on the images like as follows:
* Check each components and line paths.
* Replace if found open or shorted
* Jumper the line paths if found open or cut
* Check or replace the digi mic knopfler for a quickest step might as possible.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnUknz7xAI/AAAAAAAAAiQ/McXux--YsDc/s320/nokia+5800+xpressmusic+digi+mic+knopfler+repair+gu ides.jpg
The microphone's digital data signals has also a line paths connected to the front side of the Printed circuit board, check and trace also this line paths which is connected to digi mic knopfler's pin 4
Feb 17, 2011 | Nokia 5800 XpressMusic Smartphone
We have bought a digi box for this tv but can not tune the tv
hello make sure the aerial is connected to the digi box then a lead from the digi box the the tv also connected a scart lead from the digi to the tv the go into the menu choose first time installion click ok the it should search
regards
shaun
Mar 27, 2010 | Televison & Video
How can I set up my set top box so that I can still record shows from the TV on my VCR?
Take the main aerial and plug it into the digi box,then take a male to female fly lead from the digi box and plug into the vcr,then take another fly lead from the vcr and plug into the tv.Connect the digi box to the tv using a scart lead.
Jan 06, 2010 | Televison & Video
How do you connect the digi box to tv and vcr
Put the main aerial into the digi box,connect a fly lead from the other connection on the digi box and plug it into the vcr,then take another fly lead from the vcr and plug into the tv,connect the digi box to the tv with a scart lead.
Dec 12, 2009 | Televison & Video
How do I connect to a TV & Digital Set Top Box? Which plugs go where? I have no manual to follow. Thanks for your help.
Connect aerial to digi box first and then from it to the vcr and from the vcr to tv. Scart from digi box to Scart in on vcr then scart out on vcr to tv.
Nov 20, 2009 | LG Televison & Video
How do you set up digi box with VHS recorderand Tv. Digi box has two scart leads
Take one scart from the digi-box & connect the other end to the TV, & the second scart on the digi-box can connect to the VCR. To record from the digi-box, the VCR must be set to the AUX input (or AV ). The TV will also be set to the AV input, this set up will let you watch digital channels & to record a digital source. Be aware depending on your type of digi-box, you may not be able to record & watch two different digital channels at the same time.
Oct 14, 2009 | Electronics - Others
Hii i cannot connect my tv to the dvd player , can u tell me how can i fix this problem
I wrote this down to connect at Digital Freeview box to TV and to Video. It works for me on a portable TV and I am a grannie so if I can do it ............ I did buy one of those scart boxes which allows 4 scart leads just like an electric plug multi socket, very cheap price. Hope this helps and Happy New Year.
Take the scart connector box lead to the digi box.
The scart from the TV and the scart from the Video both go to scart box.
TV aerial itself not plugged in or used.
Bottom video aerial to right digi hole
Another aerial lead (not aerial) from TV hole to left digi hole
Jan 02, 2009 | Insignia LCDTV26 26 in. Television
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Computers & Internet Logo
150 people viewed this question
Top Digi Computers & Internet Experts
doggzzz
Level 1 Expert
Alun Cox
Don Hart
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
