Question about Ricoh Aficio AP410N Laser Printer
Having to press paperfeed then enter to print
When I send something to be printed through the network then go to the printer to get it, I first have to press the paper feed button then the enter button before it will print. Problem, if I need to send more than one thing to the printer, the second item will come up with an error because the printer is currently waiting on me to push the paper feed and enter buttons. How do I change this so it will automatically print without me having to press the two buttons???
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ricoh Master
  • 1,362 Answers
Most likely the paper settings are wrong. it should be set to letter and plain.
go to the menu and look for paper settings
Posted on Oct 07, 2008
Xerox Work Centre 7545 won't print from my computer
The problem may lie in the print server, and not your pc. Have an IT administrator check the drivers and ports.
Oct 19, 2012 | Computers & Internet
Hi, I am having problems printing a Word document. When I press Print, it only prints two-thirds of the page. What am I doing wrong please?
Okay, the paperfeed at the top, on the left hand side there is a grey slide, (right in the printer) to hold the paper in place. Use it to keep the paper straight! It seems that if the paper goes in straight, the whole page is printed, if it doesn't it messes up the page.
Worked for other people having trouble with Epson Printers
Sep 15, 2011 | Epson Office Equipment & Supplies
I had a paper jam and cleared it. Now the power light and paperfeed light are on and won't go off. I cannot print nor turn off the printer via the buttons. I have reinstalled drivers, opened the back panel...
What precisely IS the error message? In lieu of this information, unplug the printer. Check the paper path thoroughly including between rollers. Any tiny fragment will jam. Use a falshlight and magnifier if you must. Load with normal thickness printer paper. Plug the unit in. Hold the power button down for 10 seconds. Test page should print.
Oct 21, 2009 | HP DeskJet 1220c InkJet Printer
No print outcomes from hp laser jet printer.
Restore Your Printer To Factory Default Setting.
To restore the factory-set defaults
1. Press MENU/ENTER.
2. Use the < or the > button to select Service, and then press MENU/ENTER.
3. Use the < or the > button to select Restore defaults, press MENU/ENTER, and then press
MENU/ENTER again to confirm your selection.
The device automatically restarts.
Configure the printer as below :
Network configuration
You might need to configure certain network parameters on the printer. You can configure these
parameters from the printer control panel, the embedded Web server, or for most networks, from the
HP Web Jetadmin software.
NOTE For more information about using the embedded Web server, see Using the embedded
Web server.
For a complete list of supported networks and for instructions on configuring network parameters from
software, see the HP Jetdirect Embedded Print Server Administrator’s Guide. The guide comes with
printers in which an HP Jetdirect embedded print server is installed.
Manually configuring TCP/IP parameters from the printer control
panel
Use manual configuration to set an IP address, subnet mask, and default gateway.
Setting an IP address
1. Press Menu.
2. Press to highlight CONFIGURE DEVICE, and then press .
3. Press to highlight I/O, and then press .
4. Press to highlight EMBEDDED JETDIRECT, and then press .
5. Press to highlight TCP/IP, and then press .
6. Press to select CONFIG METHOD.
7. Press to highlight MANUAL, and then press .
8. Press to highlight MANUAL SETTINGS, and then press .
9. Press to highlight IP Address:, and then press .
10. Press the or arrow to increase or decrease the number for the first byte of the IP address.
11. Press to move to the next set of numbers. (Press to move to the previous set of numbers.)
NOTE To cycle through the numbers faster, hold down the arrow button.
12. Repeat steps 10 and 11 until the correct IP address is entered, and then press to save the
setting.
13. Press Menu to return to the Ready state.
Setting the subnet mask
1. Press Menu.
ENWW Ne.
If problem persist , reinstall the drivers .
Aug 07, 2009 | HP LaserJet 3015 All-In-One Printer
How to wirelessly print to HP 2410v Photosmart printer
This is the official how-to for network setup from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00781863&lc=en&dlc=&cc=us&product=303759&lang=
Introduction Print the network configuration page and obtain the IP address, subnet mask, and default gateway address for the printer. Printing the network configuration page
  1. Press the Setup button.
  2. Press the arrow buttons to select Network and then press OK .
  3. Press the arrow buttons to select Print Network Configuration Page and then press OK . The Network Configuration Page prints.
Obtaining the IP address, subnet mask, and default gateway address The IP address, subnet mask, and default gateway address are printed on the Network Configuration Page
The manual link is here:
http://h10032.www1.hp.com/ctg/Manual/bpu70241.pdf
Hope this helps:
WizardRepair
Jul 18, 2009 | HP Office Equipment & Supplies
Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Mar 12, 2009 | Xerox Phaser 8500/DN Printer
Print sent fax confirmation sheet
perform the steps below:
1. Press Setup on the front panel of the All-in-One.
2. Press 5 or scroll down or use arrows to enter in to Print Report.
3. Press 4 or scroll down or use arrows to enter in to Fax Confirmation.
Now scroll down or use arrows to find print after send fax and click on.
Jan 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
I have a new canon mp210 printer ink is low i bought new ink to replace old their is no ink cartridges in printer. When i look at the pictures to load new ink and put it in alarm light is flashing
Even if the ink level is low, you can continue printing.Press the paperfeed knob for 5 seconds. inklevel indicator will stop now.
Sometimes a new (or refilled) cartridge is not recognised correctly.
When one color is really mt, stop printing and replace inmideatly the colorcartridge.Printing or scanning without the 2 cartridges in place is impossible.
Dec 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Prinitng Problem OKI
A printer only prints what it gets from the pc/network. Therefore I would uninstall and reinstall the driver on your pc/server. Do not use the cd provided but download the driver from OKI's website.
Jun 25, 2017 | OKI C5800Ldn Led Printer
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
Ricoh Aficio AP410N Laser Printer Logo
124 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
